RPM drop issues
Old Feb 24, 2014 | 04:59 AM
noob23genTL's Avatar
RPM drop issues
I've been having some issues with the RPM dropping when either making sharp turns or using the power windows.
Already replaced the battery because it was old, but the power drop still persists.
I recorded a video to show exactly what happens:
Old Feb 24, 2014 | 06:53 AM
Turbonut's Avatar
Power steering utilizes a mechanical pump that when called upon pulls power from the engine as indicated by the drop in rpm, then corrected by the ecu. Any unit that "pulls" power from the engine when activated, e.g. ps, a/c, or even heavy electrical draw, load on alt, can cause the engine RPM to drop slightly when activated.
Old Feb 24, 2014 | 09:25 PM
Jesse729's Avatar
I believe most cars do that and it is normal. I think it is a little more noticeable in a car with drive by wire rather than cars that had a mechanical idle air control valve.
Old Feb 25, 2014 | 03:30 AM
Thanks for the input. I guess I was getting concerned about nothing in this case.
Old Feb 25, 2014 | 07:18 AM
ZOMGVTEK's Avatar
Every car I ever drove did this, except the Model S.
Old Feb 25, 2014 | 07:25 AM
Originally Posted by ZOMGVTEK
... except the Model S.
fuct
May 14, 2017 09:43 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
Sep 14, 2015 10:09 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
nuldabz
Sep 3, 2015 05:49 PM
