Rotors
Old Feb 24, 2011 | 09:09 AM
moprzed1's Avatar
Rotors
I need a set of new rear rotors since while breaking the car makes a loud knocking noise coming from the rear. After changing the pads it continues to do the noise. Any recommendations on new rotors????
Old Feb 24, 2011 | 09:12 AM
jda123's Avatar
Dogmatic Dinosaur
There are tons of threads on this with tons of opinions.
While you search and read, you need to decide if you want near-stock performance or if you have a need for better performance. Price will be the largest factor in this.
Also, confirm that you actually need new rotors. Did you inspect them when you put the new pads on? Are you sure that the issue is not a bearing or a missing rotor or bracket bolt?
Old Feb 24, 2011 | 09:27 AM
moprzed1's Avatar
I'm still trying to locate the problem. When driving at a higher speed and when I attempt to stop I get a thumping/knocking inside the car. Sounds like its coming from the rear. At first, I thought that it was the pads so I ended changing them since they were low. The problem was slightly repaired but still there. So now I think its the rotor but not sure.
Old Feb 24, 2011 | 11:46 AM
nfnsquared's Avatar
Year, miles, AT or MT?
Rotor would be low on my list (bad/sticking caliper?). I'd take it to a brake shop and let them do a free brake analysis...
Old Feb 24, 2011 | 12:50 PM
Bearcat94's Avatar
AZ Community Team
^^ agree.
Check for a stuck/damaged caliper first. You might need rotor replacement, but if the cause is the caliper, you need to fix both.
Old Feb 24, 2011 | 02:51 PM
SpiderX1016's Avatar
Did one side have more pad wear than the other?
Old Feb 25, 2011 | 06:31 AM
moprzed1's Avatar
Yeah it seemed like one side had more wear than the other but not too much more.
Thanks to all for your input. I will take it to a break shop and see what they say since I dont want to spend the $$ on new rotors and continue to have the problem.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
