Rotating projector inside headlight
Old Aug 12, 2011 | 01:51 PM
TUBHMOOBVAJ's Avatar
Wondering if anyone has had the same problem I do. My 07 TSX has the passenger-side HID projector rotated a bit clockwise, which messes up the cutoff on both sides.
The adjustment on the headlight itself is only up-down -- and my acura dealer doesn't know how to adjust it CW/CCW. Has anyone had the same problem? Any fixes? Help!
Would sticking my hand into the back of the headlight and grabbing the projector to rotate counter-clockwise solve this?
Old Aug 12, 2011 | 01:53 PM
Good job. I hope you get the help you need.
hopefully the lighting/projector guru's will chime in
Old Aug 12, 2011 | 02:08 PM
bforbrian's Avatar
That isn't adjustable outside of the headlight. Up/down is rectified by simply using the phillips screwdriver but CW/CCW can only be rectified by opening up the headlight. My guess is that the mounting points of the projector unit and the back housing isn't fully bolted on, causing a shift with respect to left/right, not up/down. The projector isn't able to be rotated so the entire projector unit (the piece that attaches the projector) has been shifted.
LoveMyTL-S's Avatar
I'll move this thread to the 1GEN TSX section. Perhaps you can get some help there.
Old Aug 12, 2011 | 02:36 PM
LMTLS - I've already PM'd you butt I believe he would get the most help in the 3rd gen TL section.
We have lots of lighting and projector experts.
thanks,
Justin
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
ROWDY621
Sep 30, 2015 03:20 PM
hashbrown
Sep 29, 2015 12:13 PM
