Rev limiter kicking in while driving?
Old Nov 18, 2013 | 07:39 AM
das22's Avatar
3rd Gear
Hello and thank you in advance for your help.
I have. 04 TL base AT with 125k. The timing belt snapped back in august at 75 mph (prev owner did not replace the timing belt correctly.) anyway, I got a really good deal on a used engine with 95k. The engine came from a manual vehicle.
The engine was installed and it runs fine. Except when it hits about 5500 in whatever gear it stays there. You can floor it and it just stays at 5500. As if the rev limiter was on all the time. I can hear VTEC kick in yo but that's about it.
The check engine light is on for catalytic eff below threshold. But it was on before the engine replacement. Any help or tips would be appreciated!!
Old Nov 18, 2013 | 07:41 AM
maybe APP Sensor?
Old Nov 18, 2013 | 07:59 AM
das22's Avatar
3rd Gear
Thanks! I will look into it.
Old Nov 20, 2013 | 06:27 AM
das22's Avatar
3rd Gear
Anybody else have this problem or any advice?
Old Mar 5, 2014 | 08:03 AM
BAM1369's Avatar
I am having the same problem! I thought it might be the oil getting low or needed to be changed but after a fresh change it still does the same thing. I have 125k on the original engine. I keep up with all the required service, timing belt, tranny flush and ect. I have read all kinds of "it could be this, it could be that" Does anyone have a solution to this? No I do not have a check engine light on....
Old Mar 5, 2014 | 08:05 AM
Without KNOWING what it is, that's all we can do OVER THE INTERNET. is guess.
it may be the APP sensor.
Old Mar 5, 2014 | 08:09 AM
the acceleration pedal position sensor works in tandem with another sensor near the Drive by wire throttle.
if the two sensors dont match via voltage, the car will be sent into limp mode, or a protection mode. limiting upper or higher RPMs where damage can occur.
Old Mar 5, 2014 | 08:10 AM
BAM1369's Avatar
Yes while driving. this happens in 3rd and 4 gear. in 3rd it goes to 5500 rpms hits the limiter then shifts to 4th. I have an automatic btw.
Old Mar 5, 2014 | 08:13 AM
only 3rd and 4th?
i doubt it's the app sensor, as it would affect all gears.
so, yes...any more information you can give us would be great.....
because we're still guessing.
BAM1369's Avatar
So your thinking its an electrical issue? I do have 2 12'' alpine type R's installed. could that affect anything? maybe alternator going out...?
Old Mar 5, 2014 | 08:15 AM
and the guessing game continues.
BAM1369's Avatar
Ok. When i leave work today at 4pm Ill try in first and second. I only noticed this and only tried it on the highway when aggressively passing someone.
Old Mar 5, 2014 | 08:16 AM
no, if the app sensor fails, it would give off a different voltage, one that doesnt match the dbw sensor.
you could test the app sensor with a multimeter, however, I dont know the specific values.
Old Mar 5, 2014 | 08:33 AM
Jesstzn's Avatar
You have no lights BUT do you have any codes?
Old Mar 5, 2014 | 08:36 AM
BAM1369's Avatar
My $50 walmart code reader says no codes..
Old Mar 5, 2014 | 08:38 AM
Jesstzn's Avatar
will that read all the codes?
Old Mar 5, 2014 | 08:40 AM
BAM1369's Avatar
It does when i have a check engine light on. I have cat deletes and about every 6/12 month they throw a code and i just clear it off.
Old Mar 5, 2014 | 08:42 AM
Jesstzn's Avatar
K .. just wondering cuz I know that on some cars it only reads some , not all the codes.
Old Mar 5, 2014 | 10:10 AM
BAM1369's Avatar
Ok, I took a "quick" break from work... I can redline in first and second but not 3rd or 4th. Not enough room to red line in 5th lol.
Old Mar 5, 2014 | 10:46 AM
BAM1369's Avatar
Also, I did have the battery disconnected and reset the ECU last night and hooked it up before work this morning.
Old Mar 5, 2014 | 10:47 AM
sounds like a transmission issue.
it's not the APP if you can activate vtec in first gear.
tottaly not sure im still guessing
Old Mar 5, 2014 | 11:03 AM
BAM1369's Avatar
i have searched everywhere and can not find a solution for this. I really really don't want to take my chances at the dealership and really don't want them hitting redline in my car.
Old Mar 5, 2014 | 12:10 PM
Jackass's Avatar
Because they may do it wrong?
Old Mar 5, 2014 | 12:15 PM
mzilvar's Avatar
Weird if it went into limp mode it limits rpm to like 2k so I don't think its that.
Dunno... Maybe try cleaning the injectors? I use Berry Mans total fuel system clean not very often at all just put a bottle in when the tank is almost empty and fill up with fuel. I'll put it in at the pump before I fill up so it mixes with the fuel.
Shot in the dark though, that's how they implemented the rev limit on the car is by cutting fuel to the injectors cheapest thing to try though
Old Mar 5, 2014 | 12:20 PM
yeah but, he can exceed 5k in first but not 3rd.
I would think that the injectors wouldnt work properly for all gears.
same for the APP sensor.
if its only limited to 3rd and 4th gear...
Old Mar 5, 2014 | 03:24 PM
Will Y.'s Avatar
Registered but harmless
Did anyone mention the 3d & 4th gear pressure switches yet?
Old Mar 5, 2014 | 03:36 PM
BAM1369's Avatar
I thought about that too just because I've been interested for a while to see how that would change the shifting my AT but I really don't feel like it is a tranny problem though. Why would the AT only let my engine get up to 5500 rpms?
Old Mar 5, 2014 | 05:36 PM
Jesstzn's Avatar
Still lots of guessing going on. Bite the bullet and get the codes properly read.
Also the dealer doesnt have to red line it .. It wont go there .. You could do it for them.
Old Mar 6, 2014 | 08:34 AM
BAM1369's Avatar
So when I disconnected the battery overnight, drove to work, drove on my lunch break and then on my way home.....Problem fixed!! I thought it was kinds odd that I have to drive it 3 times before the problem went away. I know that was the case when my light turned on for the bad gas cap.
Thank you to everyone for your help and input!!
I hope this helps out someone else one day.
Old Mar 6, 2014 | 10:35 AM
paperboy42190's Avatar
All you did was temporarily clear the codes by disconnecting the battery. The problem isn't fixed yet. It'll come back, it's just a matter of time.
Feb 25, 2020 09:57 AM
Sep 14, 2015 03:16 PM
PortlandRL
Sep 14, 2015 12:01 PM
LAMike240
Sep 3, 2015 04:35 PM
