Reuse rotor on only one side?
Old May 26, 2023 | 02:51 PM
redbeard1's Avatar
Hello,
My driver rear caliper has begun to randomly seize and has used over 80% of my pads. I imagine the heat has damaged the rotor. I replaced all four of my original pads with OEM about 5000 miles ago. All four rotors were within spec so I reused them. The rear passenger pads have very little wear (My original pads lasted for 100,000 miles).
I ordered a set of driver and passenger rear calipers, pads, and rotors from rockauto and had planned to replace both sides but I am having trouble with one rotor screw on my rear passenger rotor.
Is it OK to just change pads, rotor, and caliper on the driver side and leave the passenger side with original caliper, 95% life pads and original (still in spec) rotors?
If not, is it OK to just change pads, rotor, and caliper on the driver side and to just change the caliper and pads on the passenger side and reuse the original (still in spec) passenger side rotors?
I’m using the lisle hand impact driver and it worked well on three of the screws but the fourth is stripping. I used Kroil on the screws overnight.
Old May 26, 2023 | 04:38 PM
Don't half ass the job when you're already 80% of the way there.. just get a drill and drill out the screw and pop off the caliper and use some vice grips to remove it completely.
Old May 26, 2023 | 05:18 PM
redbeard1's Avatar
Thanks for reply. Screw is finally out.
For anyone with this issue, I applied more Kroil, waited a few hours, tapped the screw with a punch, then tried again with the hand impact driver.
Old Jun 5, 2023 | 10:16 AM
twokexlv6coupe's Avatar
The hand impact driver is worth it's weight in gold when it comes to taking those DAMN rotor screws out
On almost all of my cars I remove the rotor screws initially, toss them in the garbage, and never re-install them ever again.
Heptone
2G CL Problems & Fixes
Oct 1, 2017 07:34 PM
LeVeL
Nov 2, 2016 03:27 PM
thewrangler99
Mar 12, 2015 08:58 PM
Osman.S
4G TL Problems & Fixes
Apr 4, 2013 08:26 PM
Ryoko
Integra
May 23, 2012 11:28 AM
