Restarting ECU
Old Mar 14, 2007 | 10:51 PM
TLheaven's Avatar
Shyne
Exclamation Restarting ECU
Hey, does anyone know how to restart the ECU other than unplugging it and then replugging it? I think I remember something about pressing down on the pedal or something. Thanks.
Old Mar 15, 2007 | 12:37 AM
01tl4tl's Avatar
The typical method is to remove the battery NEG cable from its terminal post
Estimates vary betwen 5 and 15 minutes before reattach cable
That should reset your ECU
Old Mar 15, 2007 | 05:18 PM
Xx06SickspdTlxX's Avatar
06 TL 6spd. Navi/A-spec
A good way is the same as above but remove both negative and positive battery cables from the battery and touch them together for 30 seconds and that will reset all vehicle systems.
Old Mar 20, 2007 | 09:38 AM
NedShneebly's Avatar
practicing nihilist
This produces the 1.21 jigawatt arc necesarry to initiate the flux capacitor.
Old Mar 20, 2007 | 06:16 PM
csmeance's Avatar
Old Mar 20, 2007 | 08:34 PM
StYLeZz101's Avatar
umm i heard that u diconnect the negative battery cable for about 20 mins and have the headlight or dome lights switched on to drain everything
Old Mar 20, 2007 | 09:28 PM
01tl4tl's Avatar
When the Negative battery cable is disconnected there is no electricity flow to drain
Just leave it off for 15 minutes and all will be well
Take them both off and clean while you have a few minutes to kill
Old Mar 21, 2007 | 12:15 AM
TLheaven's Avatar
Shyne
thanks for all the tips!
TypeS860
Jan 10, 2026 11:11 AM
Puma Jim
20
Oct 20, 2016 11:59 AM
Skirmich
Oct 1, 2015 12:59 PM
malvothegreat
Sep 29, 2015 12:38 AM
