Reset maintenance minder
Old Jul 16, 2010 | 02:39 PM
RickMullin's Avatar
My car is an 2007 Acura TL type S which I purchased in Houston. The maintenance minder came on with a B12 alert which when I looked it up was an oil and filter change as well as an air filter and cabin filter change. I completed all of the requirements and followed the instructions in the manual to reset the maintenance minder to the letter.
Is there some sort of trick to the reset?
Old Jul 16, 2010 | 03:18 PM
wrxyboy's Avatar
1st TL-S on air in
if you did it right it should reset
Old Jul 16, 2010 | 09:31 PM
LoveMyTL-S's Avatar
Search turned up these threads:
https://acurazine.com/forums/3g-tl-2004-2008-93/reset-service-reminder-557416/
https://acurazine.com/forums/3g-tl-2004-2008-93/oil-life-reset-3g-garage-f-157-a-556666/
Hope this helps..........
Old Jul 16, 2010 | 09:57 PM
1islandparadise's Avatar
If you are getting the little "envelope" on the top corner of the nav screen I would take off the neg battery terminal for a few minutes. I done this to reset a message I had stored in mine. ENSURE you have your NAV and radio code! As far as resetting the oil life indicator just hold the reset button on the right side of the steering wheel for about 10secs. More menu's will pop up to reset it.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
brboy
Oct 5, 2015 11:34 AM
Froid
Sep 27, 2015 06:16 PM
ceb
ILX
Sep 27, 2015 10:56 AM
