Replacing Front Engine Mount
Hi Peeps.
I have a 2006 TL that needs at least one motor mount. Through a little research I decided to start with the front mount as it was the most consistently mentioned for replacement with my symptoms.
My question is:
If $120 - $200 seems to be the going rate for a front engine mount, other than the branding, whats the difference between those brands like Westar for $38? I know the quality will be inferior but im in a pinch. The reason im asking is because Im not very familiar with Acura yet and I have read that there are vacuum lines that are attached to the mount and will will trigger a SES light when they fail. The only thing I can think is that theres no vacuum attachment, that its just a mount to hold the engine.
Westar $38.00
2004-2008 Acura TL Engine Mount - Engine Mechanical - Westar, Front 04-08 TL Engine Mount - 17777-05200935 - PartsGeek
Anchor $146.00 Anchor 9247 - Engine Mount | O'Reilly Auto Parts
OEM $159 - $213
Any thought? Experience... Thanks in advance
My question is:
Westar $38.00
OEM $159 - $213
I have a little info to add:
The cheap ones are solid or hydraulic WITHOUT vacuum attachment. Stock is hydraulic and has a vacuum line that stiffens the mounts under acceleration.
"IF" I were to get a solid or hydraulic without vacuum attachment, what do I do with the factory vacuum line? Plug it, im assuming, but what about trouble codes from using a mount that doesnt have a vacuum line?
If I was you I wouldn't care about the branding. I bought mine off ebay. All 3 for about 150 if I remember correctly. Usually they have some Acura vendors on there and sell OEM for cheap, So I would check there first. 2nd. Dont worry to much on the vaccum line. I did plug one in, but the other two I left off, and I haven't had any issues now for three years.. I just know it was a pain in the ass of a job. You will wanna use some PB Blaster and let it sit there.
I went oem at a much more considerable cost than these below, and if your front is bad, budget for ALL of them, they'll all likely need replacing:
Complete set of engine, transmission, and two sub-frame mounts for $189.75 shipped.
I bought my 3 engine mounts on ebay for 120$ shipped to Canada. The seller was "autoenginemounts". Installed the front and side about 6 months ago, the front did have vaccum hose plug. No issues since, he does offer a 5 year warranty. I installed the rear a few weeks ago, it didn't have the vacuum valve, i just plugged the hose and don't have any problems.
Great info!! Thank you guys! I dont know that im willing to tackle the entire set currently. Im in a place at the moment that lacks a garage. :/ Im gonna go for the inexpensive front solid mount and call it a day. Thanks for sharing your experience with the vaccum line! That was my biggest concern. I expect more vibration from the inexpensive one, just as I would expect more squeaking and brake dust from cheap vs. high quality brake pads. Anywho, Thanks again everyone!!
Not true about non oem mounts, came across these on eBay the other day, look at bottom, inlet is there.
CheeseyPoofs McNut
10-02-2016 11:37 AM
Jimmy_D
01-07-2016 07:18 AM
