Removing the entire Dash Panel Help
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I punctured a hole through part of the heater core, just to the right of the gas pedal. I goofed up and drilled a screw through a plastic piece which I thought had enough clearance. Punctured the heater core and had radiator fluid spill out. ![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Anyway... According to the Acura Service Manual, I have to remove the entire dash to get to the heater core. I am almost done removing the dash, but question is why do I have to remove the entire steering column? Manual states to run a wire along the slider shaft to prevent the shaft from pulling out. Anyone have any suggestions / tips on removing the dash panel? Do I have to remove the steering column?
mada51589
05-03-2022 08:54 PM
BoricuaTL
04-08-2016 01:08 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
