remote not linked
Old 09-02-2008 | 09:46 AM
jd34's Avatar
remote not linked
for some reason the driver 1 remote isn't linked anymore. does anyone know how to re-link the remote without taking it to the dealer? thanks guys.
Old 09-02-2008 | 09:55 AM
BG74's Avatar
Press and hold lock & unlock together for a few seconds...that'll do it!
Old 09-02-2008 | 02:39 PM
jd34's Avatar
Thank you. I'll give it a try.
Old 09-02-2008 | 09:55 PM
mattster's Avatar
Driven to Perfection
I thought mine came unlinked, and then i remembered that I put the Driver 2 key in the center console for some reason. I took the Driver 2 key out of proximity of the car and now I see "Welcome Driver 1" on the Multi-Display. BTW: Is there anyway to change that message to say something else?
Old 09-02-2008 | 10:12 PM
csmeance's Avatar
you cannot make it say something else unless you want to have a programmer edit the chips inside the board to display it which would be $$$$
Old 09-03-2008 | 08:37 AM
jd34's Avatar
Driver 2 key is in the house, i tried holding lock and unlock together and it didn't do anything.
Old 09-03-2008 | 12:47 PM
BG74's Avatar
I thought you meant the memory function was unlinked...if it's not working at all (if you're sure the battery is good), here are the reprogramming instructions:
https://acurazine.com/forums/3g-tl-2004-2008-93/programming-remote-transmitter-keyfob-3g-garage-l-079-a-556315/
Old 09-04-2008 | 10:51 AM
jd34's Avatar
Thanks BG
Old 03-14-2017 | 07:48 PM
IMJFP's Avatar
5th Gear
that's not for linking the remotes (Driver 1 or 2 for seat memory settings) its only for adding new remotes for locking and unlocking....
07-16-2017 08:33 AM
eastcoastguy
10-29-2015 04:00 PM
thegipper
09-28-2015 02:01 PM
