remote for 04 tl help
Old Apr 7, 2007 | 12:20 AM
silveracid's Avatar
just bought a` new remote memory #2 how do you program it to work with the car need help
Old Apr 7, 2007 | 09:06 AM
Xx06SickspdTlxX's Avatar
06 TL 6spd. Navi/A-spec
Alright well first get into the car have all your remotes in hand, put the key into the ignition then turn the car to accessory 2 which is right before start, then hit the lock button on the remote then turn the key off and repeat this consecutively about 3 times until you hear the locks engage then once you hear them hit the lock button once on each of your remotes, you will hear the locks engage each time and them turn the ignition off and try the remotes they should all work! If you dont get this its kind of hard to explain...
Old Apr 8, 2007 | 09:30 AM
john caravello's Avatar
The precedure is in the 3g garage. https://acurazine.com/forums/showthread.php?t=89492
Old Apr 8, 2007 | 06:58 PM
silveracid's Avatar
Thank you thank you
worked like a charm thanks guys i really appreciate all help
Old Apr 10, 2007 | 12:09 PM
B16A2/EG6's Avatar
__B-Series-ous__
If you find this out let me know, i just got an 05 and looking to program my memory two.
Just found the instructions thxs.
Old Apr 10, 2007 | 01:01 PM
TLRIDA's Avatar
does that work for the 04 tl also ?
datadr
Mar 23, 2016 01:39 PM
eastcoastguy
Oct 29, 2015 03:00 PM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
saturno_v
Sep 27, 2015 08:13 AM
