Rear Windows Fog Up
Old Feb 6, 2006 | 08:29 AM
pvansh's Avatar
05 WDP/Ebony/5AT/NaviLess
Rear Windows Fog Up
Hi All,
I did a search but didn't find anything that related to this problem.
I've noticed lately then when it is wet outside (rain or rain/snow), my rear windows seem to fog up easily. I have to keep playing with the climate control to clear them up and often times even that doesnt work. If I have passengers in the back its even harder to clear them up. I took it to the dealer and they said "there is nothing we can do about it, its normal" which kind of pissed me off. Any idea if this is something wrong with my car or perhaps something wrong with what I am doing?
Any help would be appreciated, thx!
Old Feb 6, 2006 | 08:40 AM
ml3456's Avatar
I am noticing the same issues. I see there are some vents that go under the rear deck. It may be fore the sound system. I need to look a little closer and see if moisture from somewhere else is getting up there.
ML
Old Feb 6, 2006 | 08:46 AM
Bplayer's Avatar
There is a film that will build up on the interior glass from the materials in the car. I think this help helps fogging to occur. Cleaning the interior side of the windows may help. I use Windex rub it in, squeegee, and then buff with a microfibre.
Old Feb 6, 2006 | 08:47 AM
pvansh's Avatar
So you don't think its a door/window seal issue? That was my guess.
Old Feb 7, 2006 | 08:39 AM
pvansh's Avatar
Anybody else have this problem?
Old Feb 26, 2006 | 12:11 AM
hcekc's Avatar
Just the rear window and not the other windows? Weird.
If you get rained on and then you get into your TL with your wet umbrella and wet clothes, then ALL the windows will initially fog up due to evaporation. It's worse if you have wet passengers. Use the defrost with the AC on and that will at least clear up the front windows/windshield. You can turn up the temp so the AC doesn't freeze your ass off. Now my wife drives the TL, but isn't there a rear window defrost? Use that too, that's what it's for.
Old Feb 27, 2006 | 08:16 AM
pvansh's Avatar
I meant the back windows on the door now the rear window. It seems as though when its wet outside it just fogs up and gets hard to clear. Its worse we people in the back seat.
Old Feb 27, 2006 | 11:18 AM
elcob32's Avatar
Mine was really bad when I first got it. It would stay fogged up so long the defogger would turn off, and I would need to turn it back on before it was clear. After my windos were tinted it didnt seem to be as bad. Maybe the tint helps the heat dispersion.
Old Feb 27, 2006 | 03:28 PM
hcekc's Avatar
My bad. But still normal. You outta see my 91 4Runner. Can't be worst than that. Again turn the AC on.
Old Feb 27, 2006 | 07:09 PM
Actuary's Avatar
18,000mi. 29000km
AC helps, if its rear window then use defroster.
Old Dec 7, 2006 | 01:01 PM
tng812's Avatar
9th Gear
i have the same problem. when i hit the defroster button the lights turns on, but i dont think it is working. could it be the fuse? which fuse is it?
oyayjoe
Jan 1, 2019 10:17 PM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
oyayjoe
Sep 12, 2015 04:40 PM
EE4Life
Sep 11, 2015 10:13 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
