Rear wheel-feel shake
Old Dec 5, 2015 | 09:22 PM
Muzammil's Avatar
7th Gear
hi i ve question for experts in car , i ve 08 tl , while driving when i change lane , left to right lane i feel shake on passenger rear wheel, plz give me suggestion , its shock, or control arm ?
Old Dec 6, 2015 | 06:24 AM
Turbonut's Avatar
Need to get it up in the air for an inspection/exam.
Check for any looseness as well as the stabilizer links.
Also, once in the air, raise the wheel assembly with
a jack so the suspension is loaded, as if it were sitting
on the ground and do the check.
Old Dec 6, 2015 | 09:25 AM
StanCeD_J32's Avatar
-NoSuchThingAsTooLow-
There could be many things. At this time of the year, I should ask - did you recently put your snow tires on? if not, jack it up and check for looseness in stab links, stab bushings etc.
Old Dec 13, 2015 | 10:55 AM
Muzammil's Avatar
7th Gear
no , i did not put chains on tire.
Old Dec 15, 2015 | 06:16 PM
6MTSSR's Avatar
A bent wheel could cause that issue.Also uneven tire wear.
Old Dec 16, 2015 | 07:50 PM
csmeance's Avatar
how many miles?
Worn/blown shock, bad alignment, bad tire wear, etc. Lots of causes, need more info.
Cablerat
Jan 11, 2016 11:04 AM
LaCuRa
Dec 16, 2015 06:27 PM
michael03
Dec 4, 2015 12:54 PM
vinman1000
Dec 3, 2015 04:52 PM
MrBlackHP
Dec 2, 2015 10:22 AM
