Rear Tranny Mount
Old Jun 24, 2013 | 01:40 PM
mattymattB's Avatar
From Around The Way
Rear Tranny Mount
Whats up. Does anyone have any tips in removing the rear transmission mount ? Basically im jacking the tranny to get enough room to install it, but when there's almost enough room, the whole car starts lifting. Do i need to remove ALL the mounts so the car will lift ? Thanks
Old Jun 27, 2013 | 07:48 PM
schenley101's Avatar
I ran into the same problem when I replaced mine. Even though it doesn't look like it, there actually is enough room to remove it. The trick is to get the back out first. Keep the front as low as possible and the back high enough for the bolt to clear the subframe. Rotate the mount towards the center of the car and then down. You should be able to get the front bolt to clear the subframe and get the mount out. Hope that helps!
Yikes
May 3, 2021 04:29 PM
KB1_EJ6
Nov 13, 2016 09:51 PM
wilztlxs
Dec 1, 2015 09:16 AM
2015TLX
Sep 11, 2015 02:56 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
