Rear right abs sensor help needed!
Old Aug 23, 2011 | 03:03 PM
godfather18's Avatar
Hi guys I'm new to the forum and new to Acura TL coming from a 2001 Lexus ES300 and I love the car but the car has VSA and ABS light on so my friend has a snapon car scanner and we found the rear right abs sensor to be bad so we went ahead and replaced it with a new one and them we reset the computer with the snapon scanner and the lights came back on it still says that the rear right abs sensor has a open or short circuit! So now I don't know what the problem is does anyone here have any insite as to what it could be.
Old Aug 23, 2011 | 03:14 PM
s_vares's Avatar
You will have to trace the abs wire back to the computer and test it. I would start there, it may just be a break in the wire or connector. The downloadable service manual will help as well.
good luck
-Steve
Old Aug 23, 2011 | 04:35 PM
good luck
-Steve
While im waiting for the service manual to download where is the ABS computer located so I can check the connections?
Old Aug 24, 2011 | 12:29 AM
OK I used a multimeter to figure the continuity of the wires and wires 5 and 6 are the rear right abs sensor to give the VSA module a signal. But number 5 wire does not have continuity so the wire that goes all they way to the rear ABS sensor has a short or break somewhere from the VSA module to the wheel and I cant tell if the wire goes underneath the car or into the car.
Old Aug 24, 2011 | 01:33 PM
Alright I went and physical check the wire from the car to the abs module and found no breaks or cuts in the wire so now I have no clue whats wrong with this car jm stumped:-(
Old Aug 24, 2011 | 02:02 PM
I'm starting to think that its a bad abs sensor ring on the hub is this a possibility?
Old Aug 24, 2011 | 03:55 PM
s_vares's Avatar
You did say there was no continuity though right? That could still be the issue. double check that If you infact do have continuity, then look at the ring.
Old Aug 30, 2011 | 02:12 PM
Replaced the rear right well hub which has a brand new abs ring and still the abs light came on I have no idea what the problem is I'm at a loss of words!
Old Sep 4, 2011 | 08:52 PM
Bump any idea guys?
Old Sep 4, 2011 | 11:05 PM
COLINGER's Avatar
speed sensor
Originally Posted by godfather18
Bump any idea guys?
When I had those lights appear it was the wheel speed sensor that was the problem. Once that was replaced the lights never came back. Check it and good luck! Just for shits and giggles go to Autozone and have it rescanned too.
Old Sep 6, 2011 | 10:54 AM
I already replaced the sensor and wheel hub and I still have the lights even after I reset the ECU.
Old Sep 8, 2011 | 08:14 PM
UPDATE: Took my car to my friends shop and he connected it to his Snap-On scanner and reset the code and the lights didn't come back on!!!!!! I thought reseting the ECU would reset the abs light after I replaced the HUB but he told me that the code comes from the ABS's computer and stores the code there and not on the main ECU so the light would have never turned off if I didn't use a scanner!
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
wilztlxs
Dec 1, 2015 09:16 AM
ibGTV
Sep 28, 2015 03:40 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
