Rear right abs sensor help needed!
Old 08-23-2011 | 04:03 PM
godfather18's Avatar
Hi guys I'm new to the forum and new to Acura TL coming from a 2001 Lexus ES300 and I love the car but the car has VSA and ABS light on so my friend has a snapon car scanner and we found the rear right abs sensor to be bad so we went ahead and replaced it with a new one and them we reset the computer with the snapon scanner and the lights came back on it still says that the rear right abs sensor has a open or short circuit! So now I don't know what the problem is does anyone here have any insite as to what it could be.
Old 08-23-2011 | 04:14 PM
s_vares's Avatar
You will have to trace the abs wire back to the computer and test it. I would start there, it may just be a break in the wire or connector. The downloadable service manual will help as well.
good luck
-Steve
Old 08-23-2011 | 05:35 PM
good luck
-Steve
While im waiting for the service manual to download where is the ABS computer located so I can check the connections?
Old 08-24-2011 | 01:29 AM
OK I used a multimeter to figure the continuity of the wires and wires 5 and 6 are the rear right abs sensor to give the VSA module a signal. But number 5 wire does not have continuity so the wire that goes all they way to the rear ABS sensor has a short or break somewhere from the VSA module to the wheel and I cant tell if the wire goes underneath the car or into the car.
Old 08-24-2011 | 02:33 PM
Alright I went and physical check the wire from the car to the abs module and found no breaks or cuts in the wire so now I have no clue whats wrong with this car jm stumped:-(
Old 08-24-2011 | 03:02 PM
I'm starting to think that its a bad abs sensor ring on the hub is this a possibility?
Old 08-24-2011 | 04:55 PM
s_vares's Avatar
You did say there was no continuity though right? That could still be the issue. double check that If you infact do have continuity, then look at the ring.
Old 08-30-2011 | 03:12 PM
Replaced the rear right well hub which has a brand new abs ring and still the abs light came on I have no idea what the problem is I'm at a loss of words!
Old 09-04-2011 | 09:52 PM
Bump any idea guys?
Old 09-05-2011 | 12:05 AM
COLINGER's Avatar
speed sensor
Originally Posted by godfather18
Bump any idea guys?
When I had those lights appear it was the wheel speed sensor that was the problem. Once that was replaced the lights never came back. Check it and good luck! Just for shits and giggles go to Autozone and have it rescanned too.
Old 09-06-2011 | 11:54 AM
I already replaced the sensor and wheel hub and I still have the lights even after I reset the ECU.
Old 09-08-2011 | 09:14 PM
UPDATE: Took my car to my friends shop and he connected it to his Snap-On scanner and reset the code and the lights didn't come back on!!!!!! I thought reseting the ECU would reset the abs light after I replaced the HUB but he told me that the code comes from the ABS's computer and stores the code there and not on the main ECU so the light would have never turned off if I didn't use a scanner!
mada51589
05-03-2022 09:54 PM
02-25-2020 10:57 AM
wilztlxs
12-01-2015 10:16 AM
ibGTV
09-28-2015 04:40 AM
Stu2414
4G TL Problems & Fixes
08-30-2015 08:30 PM
