Rear power window not working at all
hey guys, first post here... i just bought a 2005 TL; anthracite gray with navi, and so far i really like it. there's a few things i need to fix, one of which is the right rear power window.
the window is not working at all. i hear no "click" or any sort of attempt by the motor. the green led on the button is also not lighting up. because of this, i'm wondering if maybe the window isn't getting power at all. i tried replacing the fuse, to no avail. i also noticed that when i took the fuse out of a working window, it still "clicked" when i pushed the button, even if it didn't roll down.
i should note that the power lock still works, so some part of the door is getting power. does anyone have any idea what a solution might be based on what i described? if i have to replace the regulator, do you have any idea how much of a bitch it would be to replace myself? i found the guide, and it doesn't look easy or fun. thanks.
craig
craig
No warranty left I'm assuming? Get it checked out, and then buy the parts cheap from junkyard or ebay or www.acuraoemparts.com
how many miles on it? Call the dealer, give them the VIN and ask if it has an extended warranty. YOu might be able to get it done under warranty if you have any left. If not, I would take the door-panel off and find the wires to the motor. Using a multimeter, check if they have power, if so the regulator might be bad. If not, follow the wires to the short, disconnect or to wherever they lead to.
i tried the window lock-out button (obviously not it), and the child safety lever... from what i gather, if the button isn't lit, it may indicate that the motor is fine, it's just not getting power. is that right?
and no, it isn't under warranty... although at least i caught before i bought it and the dealer gave me a concession to fix it.
no the car isn't under warranty or certified pre-owned. if it was, i'd be talking to the dealership...
has anyone had their motor burn out? if you did, did it still "click?" mine doesn't click or do anything at all. i haven't really had time to look at it much past that, but i will look this weekend...
does anyone have any suggestions based on the symptoms? (no clicking sound, light on button does not light up). i'm going to work on it this weekend, so if anyone has any suggestions before i start, i'd really appreciate it. thanks...
i still havent gotten it fixed. I'm just afraid that maybe its not the harness and its somthing else and my warrenty will run out.
Is it easy to take the door panel off, anyone know pls. thanx.
https://acurazine.com/forums/showthr...ndow+regulator
fixing it looks like it would be a bitch... and i'm worried i'll create a rattle in the process. i think i might go take a look at it right now before it gets to dark (it's already cold)
i hope it's just a harness that's loose or something
Problem fixed! It was the power window connector that was not connected for some reason. I partially removed the door panel and plugged in the connector. I'm guessing maybe something in the door was fixed at some point and the tech forgot to plug the connector back in.
Really glad I saved myself $125 to have the dealership diagnose and "fix" the problem
ya... my rear window doesnt work either. I took it to the dealer cause it was under warrenty and i thought it was the child lock option but they said that when my windows were tinted they forgot to plug in one of the harness. it will cost me 90.00.
mada51589
Jan 9, 2025 04:40 PM
TLDude876
Dec 28, 2016 03:18 PM
