Rear brake light in window very dim
Old Nov 24, 2010 | 08:45 PM
jattsoorma187's Avatar
6th Gear
Is this easy to replace? It is very dim and sometimes doesn't even go on when I'm braking. The tail lights are fine, just the long light in the rear window.
Old Nov 24, 2010 | 09:23 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Replace the 3rd brake light. It's an LED unit.
Old Dec 4, 2010 | 04:36 PM
DeltaCTU24's Avatar
is it possible to just replace the brake light switch and that fixes the problem?
Old Dec 4, 2010 | 06:44 PM
Indy04TL's Avatar
I was told that I needed a new third brake light by a dealer on this past Friday. ($130). I found on here that it was possibly the brake light switch. ($13). I installed a new brake light switch and and it fixed the problem!! Try it first and see if it solves your problem.
Old Dec 7, 2010 | 04:16 PM
Majofo's Avatar
It's more than likely the brake light switch. Very common issue.
Old Feb 1, 2011 | 10:05 AM
imj0257's Avatar
Q('.')=O
Mojofo, is it a new switch I need to get for the third brake light? And how do I replace the switch? And where can I get a replacement. Chop, chop!
Old Feb 1, 2011 | 10:15 AM
Majofo's Avatar
yeah, 3rd brake light switch behind the brake pedal. Easy DIY.
mada51589
Jan 9, 2025 04:40 PM
Ny1718
Sep 11, 2015 09:21 AM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
