reading both p0157 and p0158 codes?
Old Nov 24, 2009 | 11:22 PM
dimka247's Avatar
It's an 04 TL auto with 70k.
Since I bought it 2 years a go it always smelled if you pushed the car hard (rotten egg smell from the cats), but I always drove it easy and rarely had this isssue.
I gave the car to my parents in law for a road trip upstate. Turns out they drove the car (accidently) in manual mode (the shifter in that gate to the left of D) for almost 2 hours on the way there. I know.. don't get me started.
They came back with a check engine light. Codes p0157 and p0158.
The cat still only smells when you push the car, but the engine light is always on. Even if you delete it it comes back after 10-20 mins of driving.
Was the cat always bad and now become worse? Or is the oxygen sensor bad? Is it both? Please help.
Thank you!
p.s. should i change the trans fluid?
Old Nov 25, 2009 | 04:19 AM
YeuEmMaiMai's Avatar
i would not be too worried about driving the car in manual mode
the two code indicate o2 sensor problems
P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
Old Nov 26, 2009 | 05:39 PM
dimka247's Avatar
Should I just replace the oxygen sensor?
Oh, I'm sorry, I didn't explain it the right way.. they left it
in the manual mode but NEVER SHIFTED the car; the car just red lined until the computer up-shifted itself, they are an older couple so I guess they didn't notice the engine screaming or the temp gauge shooting up.
P.S. Thank you for your help.
Old Nov 26, 2009 | 07:10 PM
still won't hurt the car if they hit fuel cutoff as the ecm shifted on the 2nd bump anyways. just change all ur fluids if you are worried about it.
I would check the wiring cause it's odd to get those at the same time
mada51589
Jan 9, 2025 04:40 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
SUPRMN84
Oct 7, 2015 09:46 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
