Rattle from upper Console
Old Aug 6, 2007 | 03:48 PM
ryder1650's Avatar
I am getting a rattle in my 04 TL from the upper console, where the lights and sunroof switch are located. If I smack the console a couple times it will go away for a bit, but ends up coming back. Is there a good way to fix this?
Old Aug 6, 2007 | 04:52 PM
Yakuza70's Avatar
Sounds like you might have the same rattle as me! Check out this thead: https://acurazine.com/forums/showthread.php?t=164087
Old Aug 6, 2007 | 10:20 PM
ryder1650's Avatar
Cool thanks!
Did that work for you?
Old Aug 6, 2007 | 10:50 PM
Yakuza70's Avatar
Cool thanks!
I dismantled the upper console this afternoon. I couldn't tell exactly where the source of the rattle was so I put weatherstripping tape in the areas that looked like it might rattle. I drove it for about 15 minutes after and didn't hear the rattle but the rattle was intermittent so only time will tell if I got it fixed. It was pretty easy to dismantle the console too.
Old Aug 7, 2007 | 12:39 PM
ryder1650's Avatar
sweet, thanks!
Old Jun 14, 2009 | 05:04 PM
CJTTL's Avatar
8th Gear
Unfortunately, I have the exact same problem that is solved temporality with a firm smack to the console. Will give it a shot next weekend armed with weatherstripping. Have you guys made any further progress?
Old Jun 14, 2009 | 10:30 PM
Red Voodoo's Avatar
Area on my XM
Just an idea... I was having the same problem at one point. It sounded like it was coming from behind the Homelink/sunroof switch console. Turned out it was my driver's side sun visor when I had it down. Just moved it one direction or the other, and the rattle disappeared. Not sure if we're talking the same animal here..
mlody
Dec 4, 2019 02:11 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
hashbrown
Sep 29, 2015 12:13 PM
adreano17
Sep 29, 2015 08:48 AM
Brandle34
Sep 23, 2015 07:20 PM
