Random codes out of nowhere
Old Oct 8, 2013 | 06:13 PM
Grand_hustle17's Avatar
So I was driving today to work when I stopped for gas (7 eleven gas station) and after I fill up few miles down my CEL came on (I use 93)... after work I stopped at advance auto to get the codes scanned... there was 25 codes... WTF!!!... multiple showed up more than once.. but they seem to all be spark plug related
The car drives perfectly normal, no stuttering or anything... ive gotten a CEL once and it went away, however this one came up today and sometimes flashes... didn't like that lol...
Old Oct 8, 2013 | 06:38 PM
MarcoNorthPolo's Avatar
KCCO
I'm sure this is unnecessary advice, but check your plugs. The 3G TL has a history of spitting out one of the plugs (5 maybe I can't remember,) so make sure they are all tightened up. I wonder if having a loose plug would trip a code?
Old Oct 8, 2013 | 06:44 PM
hmm... im already buying 6 new spark plugs lol
Old Oct 8, 2013 | 06:46 PM
In my 6th gen Accord, I used to have weird codes too and it had to do with a faulty alternator. Weird electrical spikes = electronics having no clue how to react. Check your grounds and have your battery/alternator checked?
Old Oct 8, 2013 | 06:50 PM
im a bit confused about p0219 (engine overrev)... doubt I even had the car over 3500rpm and I def didn't over rev the engine
Old Oct 8, 2013 | 06:55 PM
EvilVirus's Avatar
Clear the codes and see if it comes back on again; 25 codes at once seems strange to me and you should know better than to post a problem on the general section
Old Oct 8, 2013 | 07:01 PM
oh shiz... I totally forgot there is a section for problems and fixes lmao... mods please move this lol...
Old Oct 8, 2013 | 07:02 PM
what are those 661-1 crap and 86-1???
Old Oct 8, 2013 | 07:04 PM
EvilVirus's Avatar
P0219 Acura Engine Overspeed Condition
Possible causes
- Wheel slippage (water, ice, mud, and snow)
- Excessive engine RPM in NEUTRAL Acura or operated in the wrong transmission gear
- Engine over-rev condition
- Faulty Crankshaft position sensor
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
P0219 Acura Description
Indicates the vehicle has been operated in a manner which caused the engine speed to exceed a calibrated limit. The engine RPM is continuously monitored and evaluated by the PCM. The DTC is set when the RPM exceeds the calibrated limit set within the PCM. For additional information on the engine RPM limiter, refer to Section 1, Electronic Engine Control (EC) System Powertrain Control Software.
Old Oct 8, 2013 | 07:06 PM
JJH's Avatar
JJH
Check your neg/pos battery terminal cables
Could also be the crankshaft sensor. Those things are extremely fragile and can jolt to the point of breaking contact!
Old Oct 8, 2013 | 07:18 PM
Possible causes
Symptoms
thaaaank you for the detailed info... somehow I don't feel so nervous anymore
I think its almost time to change my battery... could that be a reason???
Old Oct 8, 2013 | 08:01 PM
EvilVirus's Avatar
I think you should delete the codes and see if it comes back again. Scan regardless if it does or doesn't. If so, check your CPS. How old is your battery anyway?
Old Oct 8, 2013 | 08:05 PM
not sure.. just bought the car this past march... probably the one acura made it with lol... never really paid attn
Old Oct 8, 2013 | 08:08 PM
EvilVirus's Avatar
If its it should have the Acura sticker on it, but I doubt its your battery. If you can post all the codes you got.
Old Oct 8, 2013 | 08:34 PM
the original post shows em... some of those misfire codes show twice...
661-1
86-1
P0219
P0300
P0301
P0302
P0304
P0305
P0306
Old Oct 8, 2013 | 08:36 PM
nfnsquared's Avatar
It's possible that some of those are old codes that were never cleared and some of them are new codes.
I'm pretty sure the over rev is totally legitimate and it's likely the previous owner did it. You may or may not be sitting on a time bomb... which because of a previous over rev threw some mis-fire codes again today.
Old Oct 8, 2013 | 08:44 PM
gotcha.. car rides smooth as butter...
Old Oct 8, 2013 | 09:35 PM
JJH's Avatar
JJH
Faulty crankshaft sensor (which are notorious for going bad) can cause misfire codes I believe.
Old Oct 9, 2013 | 10:09 AM
EvilVirus's Avatar
This is the code I posted above
P0219
These are random misfire codes
P0300
P0301
P0302
P0304
P0305
P0306
CPS is probably faulty. Also, have you clean out your EGR?
Old Oct 9, 2013 | 10:18 AM
nfnsquared's Avatar
I agree, a faulty CPS could cause all of those codes, but with a 6MT my bet is: over rev...
AFAIK, CPS failure on the 3G is extremely rare... I don't remember reading about any CPS failures on this forum (yes, maybe a few ruined by DIYers, but no spontaneous failures IIRC).
Old Oct 10, 2013 | 09:48 AM
EvilVirus's Avatar
So whats the word OP
Old Oct 12, 2013 | 10:49 PM
Changed the spark plugs cleared the codes n so far no light came back... Plugs had that lil compression mark on em
Old Oct 13, 2013 | 12:03 AM
nfnsquared's Avatar
Huh?
Post a pic of the plugs.
Old Oct 13, 2013 | 08:59 AM
EvilVirus's Avatar
Good to hear no CEL is on
Jamus22
Jun 11, 2023 10:08 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
