Radio won't turn on?
Hey everyone just bought my TL today and the radio won't turn on. The battery must have been disconnected because I had to put in the pin. I did, the nav popped up but no radio? I pressed the am/fm button but get nothing. Any help would be appreciated!
Maybe you should have the person you bought the car from help you with this issue? Did the radio work when you test drove the car and now not work or did the radio never work? You might need to take the car into the dealer or get a factory manual and trouble-shoot things.
I would also check your fuses in case one burned out for some reason.
Good luck!
Good luck!
I test drove it and the radio was not on, I have a due bill that says they will fix it at no cost. Honestly I was fighting it was something simple. I tried pushing in the volume knob to no avail just an FYI. Also I am completely knew to the vehicle and never knew there were more than one code. I only entered the one listed in the owners manual
When you turn on the radio via the volume knob it should say like enter code were it shows the time up top. You use the 1-6 buttons that u use to tune to different channels. If it says this and you only have 1 code in your manual youve gotta get the other code from dealer or i think acura.com. I was locked out of my navi for a week, was tough with no backup cam lmfao.
rockyboy
08-04-2024 10:35 AM
handsom-hustla
11-13-2015 05:04 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
