Radio and clock backlight went out!!
Old Apr 21, 2011 | 11:52 AM
crw012's Avatar
4th Gear
I took my car to firestone last week to get a strut fixed and when I got the car back the radio, A/C, and clock backlights had all quit working. Everything still functions as normal just no lighting. I do have a radar detector hard wired to the sunroof controls (reason firestone claims for the problem) but I have checked the connections and disconnected it to troubleshoot the problem but nothing seems to fix it. I'm thinking that there is a ground problem or something but any help would be greatly appreciated.
Old Apr 21, 2011 | 12:13 PM
nfnsquared's Avatar
Have you checked the obvious: fuses?
Old Apr 21, 2011 | 01:34 PM
TLDude876's Avatar
Chapter Leader (Houston)
I had the same issue. Took it to the dealer and it was some incorrectly installed/bad fuse.
Old Apr 21, 2011 | 01:46 PM
crw012's Avatar
4th Gear
I've checked the fuses and they are all good, not sure how you can incorrectly install a fuse but I'll check into it.
Old Apr 21, 2011 | 02:22 PM
nfnsquared's Avatar
Both fuse boxes?
Hint: Fuse #4, 10A
Old Apr 21, 2011 | 02:49 PM
crw012's Avatar
4th Gear
Yep, checked them both.
Old Apr 21, 2011 | 02:55 PM
nfnsquared's Avatar
Did you actually pull the #4 fuse in the under hood fuse box out and look at it? You can't always tell a blown fuse just by looking at it as it sits in the fuse box.
Old Apr 21, 2011 | 04:06 PM
crw012's Avatar
4th Gear
Yeah, just checked its fine. The reason I think it's a ground and not a fuse is because the radio and everything still work and if it's bright outside you can see the radio display, it's just not lightning up.
dirleton
Aug 6, 2024 08:19 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
2Quik
Sep 23, 2015 01:03 PM
