Radiator fan still blowing
Old Aug 24, 2016 | 11:57 AM
ICeZero's Avatar
Hey TeamAcura,
I've been dealing with an issue on and off for a couple months now. My radiator fan will run when the vehicle is off until the battery dies. My solution has been unplugging my battery then when I reconnect it everything is ok. Last night that method hasn't worked. My fan turns on as soon as I connect the battery. I had my thermostat changed and I also had a crack in my coolant cap so I changed that as well. Not sure what else it could be. I recently had my serpentine belt and water pump changed but the issue started right before that. Any clue what is going on or any troubleshooting tips to isolate the issue?
I drive a 2004 Acura TL. Located in MN where the temperature is around 65-85 degrees this time of the year
Thanks,
Old Aug 24, 2016 | 12:00 PM
likely the relays are bad. check'em
Old Aug 24, 2016 | 12:18 PM
ICeZero's Avatar
Really.. How can I test it?
is this the part: 2004 ACURA TL 3.2L V6 Radiator Fan Relay | RockAuto
Also, any diagrams showing which relay it is?
Old Aug 24, 2016 | 09:13 PM
ICeZero's Avatar
I swapped my radiator fan fuse with my heater fuse, connected the battery and no success. The fan is still running. The auto store is ordering me a fuse but I'm guessing I don't need it anymore, unless both of those fuses are bad.. Not sure what else to do
Old Aug 25, 2016 | 08:21 AM
flyromeo3's Avatar
its the relay you have to test/swap out.
not the fuse.
Old Aug 25, 2016 | 05:37 PM
Baksju's Avatar
Professional Sh1tposter
I'm not an expert but could it be broken coolant temperature sensor? It might be giving incorrect readings of way too high temperature.
Old Aug 26, 2016 | 06:42 PM
flyromeo3's Avatar
^..used to be the case with accords from the early 90's.
One way to test is to turn off the car, and while the fan is running unplug the coolant temperature sensor.
If the fan turns off then there is your problem. CTS is sending a bag signal.
Old Aug 26, 2016 | 06:52 PM
flyromeo3's Avatar
you also have a condenser fan relay, radiator fan relay, in the under hood fuse box. So test them both by unplugging them when the fan kicks on and see which one cuts it off.
There is also a fan control relay in a multi relay box to the left of the underhood fusebox. It would be the relay on the left to test also.
Old Aug 30, 2016 | 05:41 PM
ICeZero's Avatar
Sorry guys got busy this week, Yes when I unplug the coolant fan fuse the radiator fan shuts off. So that means its a CTS problem.. coolant temperature sensor? I have no idea how to access that. I will do some more research.
Old Sep 5, 2016 | 12:04 PM
ICeZero's Avatar
For whatever reason my fan has been working properly now.. Whats up with that?
Old Sep 5, 2016 | 02:47 PM
csmeance's Avatar
perhaps it was a bad connection, and when you undid and and plugged it back in it's now making good contact and working!
Old May 22, 2017 | 05:51 PM
ICeZero's Avatar
Hey guys,
As the weather started to cool down last year my problem went away and I forgot all about it. Now its almost summer and my radiator fan is running again. When I unplug my coolant fuse it stops. A few of you mentioned that I should change my CTS.
Does anyone know the steps or have any resources of how to change it? Can't find much for the 3G Acura
Old May 22, 2017 | 06:02 PM
ICeZero's Avatar
Can someone confirm that this is the sensor(3:51)?
In the video he mentions another sensor behind the cylinder head. I don't have any engine light codes so I will be shooting in the dark with this fix
Old May 22, 2017 | 06:41 PM
fulla's Avatar
Can someone confirm that this is the sensor(3:51)? https://youtu.be/ZOTR3RPIsbY?t=3m51s
Hey ICeZero, the ECT, which is what your referring to (engine coolant temp) sensor is actually on the water passage, the thermostat is in the water passage. There is an electrical switch on the top side of the passage, with two wires going to it. It is close to the top radiator hose where the hose connects to the engine. I just did a complete picture job on the thermostat replacement. I've got to compile it and was going to post it in the how to section.
Old May 22, 2017 | 06:43 PM
fulla's Avatar
it's either a 14mm or 17mm wrench to remove it, I don't remember. It's on the top of the water passage and is a 2 minute job.
Old May 22, 2017 | 06:47 PM
ICeZero's Avatar
Ok Fulla, I will try to find it. Can you please ping me when you upload the picture. Thank you
Old May 22, 2017 | 06:50 PM
peter6's Avatar
You seems to be confusing relays with fuses. Did you pulled out fuse (two metal tabs) or relay (square thing with at least 4 metal tabs) ?
Old May 22, 2017 | 06:58 PM
ICeZero's Avatar
I pulled out cooling fan fuse 11 (30 amps)
Old May 22, 2017 | 07:00 PM
fulla's Avatar
you see the yellow fuse below it in the pic? Go one more down to the big black square _ this is the relay for your radiator fan.
ICeZero's Avatar
Is it the top sensor Fulla is referring to (1)?
Old May 22, 2017 | 07:05 PM
peter6's Avatar
You need to check the relay.
What it is :
https://en.wikipedia.org/wiki/Relay
What you need to check :
(photo from 2007-2008 manual, might be different)
(photo is upside down compared to your photo, fulla is right)
Your and "fixed" manual :
Spoiler
Both fans are working or only one ?
Problem with relays is that they are sometimes "sticking". Do you have multimeter with ohm or continuity checking (it beeps when two test leads connected).
If you have you can check this relay like :
Spoiler
Old May 22, 2017 | 07:13 PM
ICeZero's Avatar
So I plugged back in my cooling fan fuse(drivers side fan turns on) than unplugged the black 12V relay that fulla referred to and the radiator fan(drivers fan) stopped. Even after plugging it back in
Peter6: I do have a multi meter. You are suggesting to check the 2 relays circled plus the relay I unplugged/replugged
Old May 22, 2017 | 07:15 PM
ICeZero's Avatar
Just for clarification here is my original problem
The vehicles fan continues to run until I disconnect it either by fuse, battery, or relay
Old May 22, 2017 | 07:17 PM
peter6's Avatar
Refresh the page, I marked two wrong relays first time, in the spoiler there's your photo side by side with manual page.
Those two relays that I refereed to are identical. (two black ones)
Swap them out. Is other fan now working?
If it doesn't turn the key to second position (all lights on), make sure ac is on, then turn the key off.
Old May 22, 2017 | 07:27 PM
fulla's Avatar
no. The number 2 sensor is your ect.
Old May 22, 2017 | 07:31 PM
ICeZero's Avatar
Turning the key to accessories with the air on, both fans work. If I swap the relays no difference. Its hard to reproduce the issue; since unplugging the relay the first time, the fan hasn't turned back on. I will drive around and try to get the car hot again. So I am assuming its the ECT unless there is more troubleshooting steps I can take
Old May 22, 2017 | 07:36 PM
peter6's Avatar
Leave them swapped (black ones from the bottom). If it's relay that fails then second (passenger side) fan will stay on.
Old May 22, 2017 | 07:42 PM
fulla's Avatar
Hey flyromeo3, what happens when the car is off and the cts is unplugged and the fan cuts on? This is what my car is doing. Any ideas?
Old May 22, 2017 | 07:47 PM
fulla's Avatar
Try disconnecting the plug from the ect, does the radiator fan come on? If it does and you plug it back in does the fan still run? To get it to cut off, start your car and cut your car off or pull the fuse. I'm having a similar problem. Hopefully together and with the help of others here we can get this fixed.
Old May 22, 2017 | 08:19 PM
ICeZero's Avatar
So I realized the relay on the left allows both fans to work without the relay on the right being plugged in, so I swapped them and unplugged the right relay and the fans didn't work. So I know now that one relay is bad. (hope that sentence isn't too confusing :P )
I will have to order an extra one because I am not sure if I trust the generic ones at the store without reading the datasheet. Hopefully this fixes my issue. If not next step is the ECT. I will keep you guys posted.
Thanks for all of the help
Old May 22, 2017 | 09:28 PM
peter6's Avatar
Schematics of fan control :
Spoiler
Also if I understand correctly, you are saying that with (left) AC condenser relay (??) both fans work. Even if right (radiator fan) is removed.
It should be true as :
(assuming FANH is not engaged/conducting, otherwise only AC fan will run on high setting)
Both of them should be running, but they will be slower. Also if you turn off climate control they will shut down.
In this case engine may overheat, as there's no engine fan relay.
If high setting will be engaged, radiator fan will cut off, and AC condenser fan will work on high setting.
So don't drive with any of the relays pulled off. Better to make engine too cold than too hot.
Old May 23, 2017 | 03:41 AM
fulla's Avatar
Spoiler
Agree with too cold vs to hot. On my car, if I pull the ect harness off, the radiator fan will run on high speed. Your temp gage inside the car will go all the way to high because its unplugged and not getting a True reading.
Old May 23, 2017 | 05:45 AM
ICeZero's Avatar
Good to know! Great information, do you have the service manual? Can't find diagrams like the ones posted above
Old May 23, 2017 | 09:21 AM
peter6's Avatar
You can use forum search to find it.
How to use search :
Spoiler
Two threads with manuals :
https://acurazine.com/forums/third-g...chable-953465/
https://acurazine.com/forums/third-g...ng-all-926323/
Quick link to one of them (FallacyOfMan):
https://www.dropbox.com/s/eab30hs4xl...NP%29.pdf?dl=0
quantum7
May 23, 2017 08:33 AM
CeruleanRL
Aug 11, 2016 11:53 AM
Amitabha
Jul 13, 2016 04:33 PM
xdmds
Jun 17, 2016 11:26 AM
NEsatxTLS
Feb 12, 2016 10:55 AM
