HELP. Blinker fuse keeps blowing.
My turn signals blinker fast instead of normal speed, I do not know why. The person who owned the car before me changed the yellow driving light to a blue LED light. When I use my turn signals though it turns back yellow. Thinking the set up is probably the reason why my turn signals blink so fast.
With that being said, at random times while driving my turn signals/ hazards will completely go out. My fuse blows and I have to pull over and change it out.
Anyone have a clue why it's doing this?
Sounds like you're running low on blinker fluid... Check the resevoir and fill up as necessary..
Or just replace the bulb back to an incandescent and call it a day if you're not a fan of the LED switchback look. Or adding a resistor to prevent the hyper-blinking. Or doing the turn signal relay mod.
