Racing Idle Speed HELP
I have o4 tl 3.2 AT. 8 mos ago cyl 5 blew out spark plug stripped thread - removed head install helicoil at Machshop, replaced all gaskets coolant , oil etc IGN at TDC car starts and has whining noise from belt area - not that concerned, the real prob comes after car reaches temp it raise rpms to 4000 -4500 and drops back to 1000 , this cycle repeats itself continuously, when placed in gear idle is at 2000 , upon take off engine stumbles a bit and has no prob accel but misfires when pedal is released , checked for vac leaks , non discovered that i can tell DTCs are p0301 - 6 and P0300 all cyl random misfire What is happening
Forgot to reconnect the ECT or O2 sensor? No other codes but the 0300-0306?
Has it run fine after the repair and then just started doing this? Or did this start right after the repair?
I have to ask you this , where about would this be located , although I did not do the work I witnessed my brother doing this so if you can direct me i might just be able to locate it, I have shop manuals and a Haynes book.
Look under "cylinder head removal", "ECT (engine coolant temperature) sensor removal", "A/F sensor removal". Do you have the actual Acura TL service manual? If so, I can give you the actual page #'s.
thank you I will take a look , by the way if it's not that do you think that it could be a ground wire, I noticed that he installed a new motor mount on pass side and connected the ground wire to the engine instead of the engine mount holder , could this cause this too ?
Could also be a disconnected IAT sensor or MAP sensor. I'll bet he forgot to reconnect something.
You're sure all vacuum lines are reconnected?
I noticed that he put this wire in the wrong place is it possible that this is causeing the issue, I know it sounds really bad but I can see how this would happen but I would have not done that if I was putting back together , after all my specialty is Computers not cars and I just assumed he knew where it went I need to remove the OS pulley to remove the wire and place it in the correct location.
sorry about all the typos , I have large fingers , lol , But i would like to thank you for all the help I am going to reconnect the wire near the PS pulley and see what happens , by the way Why is it that others have reported the cylinder 5 blow out problem ?
You need to back over all the sensors and vacuum hoses that were disconnected and be sure they were reconnected.
Are you sure the only codes were P0300-P0306? If you have another code, it would certainly help narrow the problem.
yeah you're right I i have been all over those vac hoses I read somewhere that there is a vac line somewhere under the engine mount the shop manual as detailed as it is manages to not be too detailed on illustrations
joflewbyu2
10-08-2015 11:16 AM
