A quick inquiry. Thanks for your help.
Old Jan 3, 2010 | 11:40 PM
JTL__ACURA's Avatar
First off I tried searching and the search came up with a number of results.
Has anyone experienced, specifically the 2006 TL, in cold weather on start up it sounds like a whining sound coming from the alternator or somewhere near it.
But once the car is warmed up, the car drives and sounds normal.
Is this normal?
Old Jan 4, 2010 | 10:29 AM
Hyrdgun's Avatar
Love My Ride!!!
Probably tension pulley - Rt side engine bay.
Old Jan 4, 2010 | 10:48 AM
05BlkTL's Avatar
It's probably the Power steering TSB and no it is not normal operation. The O-ring on the inlet hose to the pump goes bad and lets air in causing the whine. There is a full write up on it in the 3g garage section, very easy fix if you do it yourself. Also check the inlet hose itself as the original one can have cracks in it too.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
KBTypeS
25
Oct 1, 2015 04:49 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
mellsonnj
Sep 24, 2015 04:42 PM
