question!
Old Jan 6, 2011 | 05:55 PM
wreckon06's Avatar
question!
hi all, i have a question. when i first start my car and start driving it's vibrate pretty bad. it's pretty cold in PA right now. i heard tl tends to have this problem. I wonder if that's true? i think it's worst when i keep the car at constant speed (~30-40mph). also, the steering wheel vibrate a bit when i go at 80+, is that because of alignment problem?
Thanks for reading!
Old Jan 6, 2011 | 08:49 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
please run a thread search for your vibration probs. lots of threads already.
your vibration issue could be alignment, wheel out of balance, bad axles, motor mounts, suspension, bent wheel...the more specific you can be when the vibration occurs and where you feel it, will be helpful if you want a clearer answer. otherwise please do a thread search to narrow down your specific issue.
hope this helps.
Old Jan 7, 2011 | 01:45 AM
Will Y.'s Avatar
Registered but harmless
Originally Posted by wreckon06
...i heard tl tends to have this problem. I wonder if that's true? i think it's worst when i keep the car at constant speed (~30-40mph). also, the steering wheel vibrate a bit when i go at 80+, is that because of alignment problem?
No, vibration is abnormal in any car.
It sounds like your car tires need balancing-- preferably Road Force balancing on a Hunter machine.
Also, if the vibration lessens as you drive longer, it may be because the tires are flat-spotting at the cold temperatures.
Old Jan 7, 2011 | 07:13 PM
wreckon06's Avatar
thanks for ur responses. I think flatspotting is what bugging me then. i will get it balance to get rid of the vibration at higher speed.
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
