question!
question!
hi all, i have a question. when i first start my car and start driving it's vibrate pretty bad. it's pretty cold in PA right now. i heard tl tends to have this problem. I wonder if that's true? i think it's worst when i keep the car at constant speed (~30-40mph). also, the steering wheel vibrate a bit when i go at 80+, is that because of alignment problem?
Thanks for reading!
Thanks for reading!
3G TL/2G MDX Owner
please run a thread search for your vibration probs. lots of threads already.
your vibration issue could be alignment, wheel out of balance, bad axles, motor mounts, suspension, bent wheel...the more specific you can be when the vibration occurs and where you feel it, will be helpful if you want a clearer answer. otherwise please do a thread search to narrow down your specific issue.
hope this helps.
hope this helps.
Registered but harmless
Received 1,148 Likes
It sounds like your car tires need balancing-- preferably Road Force balancing on a Hunter machine.
Also, if the vibration lessens as you drive longer, it may be because the tires are flat-spotting at the cold temperatures.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
