Question
Old Sep 22, 2009 | 11:01 PM
drew_oh_nine's Avatar
Question
my driver side headlight is starting to get that rough hazy stuff on the outside what is the best way to fix this.......and what causes this to happen
Old Sep 22, 2009 | 11:10 PM
Bearcat94's Avatar
AZ Community Team
There's a thread in here:
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
Something like headlight restoration.
Not sure of the cause. UV? Salt? I've had my '02 for almost 7 years and my headlights are in nearly new condition.
Old Sep 22, 2009 | 11:11 PM
JoeTL'81's Avatar
6speed Anthracite
A fine polishing compound and a little rubbing should take care of that.
LOOK HERE --> https://acurazine.com/forums/3g-tl-2004-2008-93/g-085-diy-restoring-hazed-cloudy-headlights-710313/
Old Sep 23, 2009 | 09:54 PM
shftl's Avatar
It's my understanding that not only will the headlight enclosure fog again, it will do it more quickly because you've cut down into the softer interior of the plastic. I would suggest that you install "clear bra for headlights" immediately after you finish clearing them. It will protect from both UV and oxygen/ozone. You can get the coverings from X-Pel or Extang, to name two, they aren't very expensive, and applying them should be fairly easy.
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
