problem with white smoke
Old Apr 14, 2010 | 04:04 PM
usaf2008's Avatar
My 05 TL with Automatic Transmission has about 95,000 miles on it. I came back from a short trip away (1 week) and noticed the engine ran slightly rougher than normal. I looked under the hood and noticed the antifreeze was significantly lower than the minimum. I also noticed some white smoke coming from the dual exhaust. It isn't heavy at all, it's barely noticeable but it is white. My question is, could I have blown a head gasket? No check engine light or service code has popped up...I thought the TL has sensors for that sort of thing and would come up with a service engine light or something. Am I just being paranoid?
Old Apr 14, 2010 | 05:43 PM
nfnsquared's Avatar
What do you mean by "significantly below minimum"? There is not much room in the reservoir below the "min" marking. Significantly below "min" would mean it was empty to me. What about the radiator itself? Did you remove the radiator cap and check it?
It's really hard to tell from here, but those are indeed signs of a blown head gasket (rough running, loss of fluid, white smoke). However, they could be coincidental as well. When was the last time you checked the fluid (both in time and miles driven)? Check your oil, does it look milky (check dipstick and remove oil add cap and check)? Has the temp gauge read higher than normal?
If your oil is milky, you've got a BHG. If not, add fluid back and monitor it for the new few days. I'd go easy on the engine until you can make a determination.
Old Apr 16, 2010 | 08:57 AM
Majofo's Avatar
Sounds like a head gasket unfortunately. Keep us updated and check your oil as suggested.
TL-Rocket
Apr 29, 2023 02:33 AM
Zonian22
Nov 14, 2015 01:20 PM
Frathora
Sep 28, 2015 11:29 PM
chuliao
5G TLX Photograph Gallery
15
Sep 15, 2015 09:01 PM
Billu99tl
Sep 13, 2015 11:30 AM
