Problem w/climate control
Old May 13, 2014 | 09:53 AM
scatsow's Avatar
3rd Gear
'04 TL - I can't adjust the fan speed or turn off the airflow. I am able to adjust the temperature, but, when my car is running the air is always on full blast.
I tried to run to self diagnostic test, but I didn't have any luck and did not receive a code. Any ideas what my problem may be?
Thanks!
Old May 13, 2014 | 10:30 AM
Vlad_Type_S's Avatar
Registered Bike Offender
Does the fan speed indicator work correctly? And your fan just spins at full speed no matter what the speed setting is? Does it blow at full speed even when the climate contol system is OFF?
Old May 13, 2014 | 10:40 AM
scatsow's Avatar
3rd Gear
Yes. Visually it increases or decreases as I adjust it, but the actual fan speed never changes. And yes it continues the blow at full speed when I turn it off the climate control
Old May 14, 2014 | 07:24 PM
wessyk87's Avatar
99% of the time that's a bad transistor ( 79330-S6M-941 TRANSISTOR )
http://www.acuraoemparts.com/delray/...All&vinsrch=no
It controls fan speed, when it fails, it has a fail safe that keeps it on full blast.
To swap out remove the plastic cover kick panel under passenger dash, I believe it's viewable there. It's held in by two screws.
Old May 16, 2014 | 01:15 PM
scatsow's Avatar
3rd Gear
Great info wessyk87. I will try this out. Thanks
Old May 16, 2014 | 04:46 PM
wessyk87's Avatar
No problem
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Sep 17, 2015 09:01 PM
HeloDown
Sep 8, 2015 06:51 PM
