Problem with removing rear seats in 2004 TL
Old May 28, 2012 | 01:47 PM
Robertttstyle's Avatar
7th Gear
I'm having a problem with getting the seat unhooked. the seat hook knobs are not budging. I don't want to just remove the back rest because I hear you can tear the seat part. If anyone has a trick to unhooking the bottom seat please show me the way. I'm getting my coilovers within 5 days
Old May 28, 2012 | 01:53 PM
SharksBreath's Avatar
BANNED
put your hand on the front bottom of the seat you'll feel a plastic clip. pinch the clips together and pull forward then pull up on the seats and the bottom seat comes out. there are 2 clips total.
for the back part, there are 3 10mm bolts on the bottom portion of the seat. can't miss them. there are also 2 10mm bolts behind each headrest. one behind each headrest.
Old May 28, 2012 | 08:17 PM
invalidalias's Avatar
if you are finding that the bottom seat pad will not pivot up after pulling the hook forward, press down on the the front portion of the seat bottom then pull hook and then raise seat bottom. As Sharksbreathe pointed out there are 10mm bolts hold the seats down were the back and bottom join. one on either side of seat bottoms. you have to pull back the pad to expose them, but they're there
Old May 28, 2012 | 09:31 PM
7th Gear
Do you have to pinch the clip to pull the clip forward? Ive tried to pull the clip forward but it didnt even want to move. I removed the bolts beforehand.
Old May 28, 2012 | 11:02 PM
Mgasttr's Avatar
7th Gear
it can be very tricky. I just removed my back seat a week ago and i had to put a bunch of weight on the seat cushion right above where the hooks are to get it to release. you may even have to use something to grip the hook. i used vice grips on the driver side. goodluck!
Old May 28, 2012 | 11:13 PM
guitarplayer16's Avatar
The key:
Old May 28, 2012 | 11:22 PM
7th Gear
The key:
the problem I have is that I cant grip the clip and push down in that area at the same time because the cushion kind of overlaps the clip unless you pull up on the seat. And pulling up on the seat makes it 100% worse to pull on the clip. This is a pain.
Old May 29, 2012 | 07:10 AM
gideon's_test's Avatar
What I did was pull up on the seat with one hand until I got a good grip on the hook handle with the other hand and keep light pressure on the hook handle, then take the hand that you were using to pull up on the cushion and give it a sharp push down as indicated in the pic shown in the previous post. It'll pop right up...
Old May 29, 2012 | 03:26 PM
con5tant's Avatar
just rip it out and replace the clips?
i think they cost me $5 for both when mine broke
Old May 29, 2012 | 11:41 PM
o666los's Avatar
I don't understand how people have trouble removing the rear seats it took me like 4 minutes the first time and now maybe like 1 min. If that!!(power tools)
Quick being a woman about it ur not gonna break a nail be a damn man
Old May 31, 2012 | 12:12 AM
7th Gear
Every car is different, troll gideon, helped me out with this a little more. Since others do know it sometimes is TRICKY, I got it within seconds after I kind of hit the top of the seat while pulling. It was stuck. Thanks for your help.
Old May 31, 2012 | 08:53 AM
BANNED
^i thought all our cars were the same?
i'm with the troll, you should be able to remove the bottom portion within 5 seconds.
Old May 31, 2012 | 05:10 PM
7th Gear
Not literally. Some clips obviously dont just pop off easily. Like mine for example.
Old May 31, 2012 | 07:03 PM
I'm with troll too
I remember it being a latch system, not a clip lol
Old Jun 4, 2012 | 07:04 PM
Flaky puff's Avatar
How about getting the trunk open? Remote doesn't work, inside release is broken. Any ideas?
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
d.lim
Sep 15, 2015 08:54 PM
truonghthe
Sep 7, 2015 11:17 PM
