Problem with driver side H.I.D
Old Nov 20, 2013 | 05:16 PM
Devers's Avatar
Hello, I just registered in hopes of getting help finding the answer to my problem.
I have a 06 3G TL Base/Nav. The problem started a couple months ago and has only gotten worse. Before the driver side HID would not go on, unless I flickered the light switch 3-5 times, it would eventually go on. Now it takes over 50 flickers for it to go on, and sometimes doesnt even come on. The passanger side works perfect. It's only the driver side that desides to be a pain in the rear!
I was thinking it could be the ballast? Or I think inverter for factory HID lights. Where is the inverter located? How much does one normally cost?
Thank you,
Mike.
Old Nov 20, 2013 | 06:09 PM
Ccvn0's Avatar
Your ballaster is bad. I buy mine on eBay. But don't buy the igniter.
Old Nov 20, 2013 | 07:20 PM
paperboy42190's Avatar
*ballast
Old Nov 20, 2013 | 08:21 PM
csmeance's Avatar
Thank you,
Mike.
The problem could be the ballast or ignitor. The easiest way to find out which component is bad is to take the parts 1 by 1 and swap them from left to right. I'd swap the ballasts first and then the ignitor. That way if the problem changes sides you know what caused it.
FYI, turning on/off HID's rapidly shortens their lifespan considerably! While you have everything apart for fixing, it might be worth your while to put in new bulbs. I HIGHLY Recommend the OSRAM CBI bulbs in 5000K. They are brighter HID bulbs with a SLIGHTLY whiter light than the factory bulbs. They run on the same wattage and these come standard on newer MB's and BMW's.
Old Nov 21, 2013 | 05:07 PM
Devers's Avatar
Thank you for your reply, I will go forth by doing just that to cancel out the problem. As for the bulbs I'll just wait, since they're still working, why pay for some expensive bulbs? Hehe.
Old Nov 22, 2013 | 12:02 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Did you buy both? I bought both from ebay.. and for some reason my DS light will always dim out to a soft white while PS is blue smh pretty sure its the ignitor.. Gotta get that fix soon..
rockyboy
Aug 4, 2024 10:35 AM
marcelft
Jul 10, 2018 06:17 PM
sockr1
Oct 1, 2015 01:31 AM
hand123
Sep 10, 2015 09:27 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
