Price on valve adjustment
Old Nov 3, 2014 | 08:20 PM
markie.markvipTL's Avatar
Was quoted $550
For labor
I bought all the parts for the job
Hes really clean and cleans all parts when putting back in
Valve covers etc etc
But for
Timing belt, serpintine belts, hydro tensioner, pulleys, water pump, gasket set, valve cover gasket and spark plugs
Thermostat and the seals,
also changing oil and coolant
$550
You tell me??
Im confused cause friend said id be paying too much
Old Nov 4, 2014 | 04:54 AM
erdoc48's Avatar
06 Anthracite TL
$550 for all the work you specified sounds actually pretty good if it includes the valve adjustment (even if you're providing the parts).
Old Nov 4, 2014 | 05:14 AM
3RDGENTL757's Avatar
550 for labor is way to much in my opinion. I charge 200 plus cost of parts to do a timing belt, t-belt tensioner, h20 pump, front crank seal, drive belt , topping off coolant and spark plugs if I do it on the side and if they want a valve adjustment add 100 to it plus parts
Old Nov 4, 2014 | 03:49 PM
nfnsquared's Avatar
OP, so for $550 labor you're getting:
oil change
serpentine belt
spark plug change
crank seals replaced
all pulleys replaced
TB service
valve adjustment
I'd say that's a fair price for labor
$300 would be a great deal. Too bad you're not in the Norfolk area...
Old Nov 4, 2014 | 08:05 PM
by the way all my parts are honda not aftermarket
Old Nov 4, 2014 | 11:49 PM
paperboy42190's Avatar
your friend doesnt know what hes talking about
Old Nov 5, 2014 | 07:44 AM
Jackass's Avatar
How much did all of the parts cost you?
Old Nov 5, 2014 | 11:00 AM
hisost's Avatar
Wow... I was quoted for $600 labor for
- timing belt
- water pump
- idler+tensioner pulleys
- hydro tensioner
- camshaft seals
- serpentine drive belt
- spark plugs
And an additional $300 for valve adjustment. I knew this was on the higher side, but had no idea it was that bad. Guess I need to shop around.
Old Nov 5, 2014 | 11:31 AM
Wow!!!!
Yeah definitely. .. buddy
& the parts ran up too like 4bills
and then I bought 6 spark plugs ngk for 62 bucks
And also just ended buying the gasket kit upper and lower
So im in it for about over a grand
bought mobil 1 synthetic ep
Etc etc...
Old Nov 5, 2014 | 02:07 PM
Jackass's Avatar
Don't think you are getting ripped off, but not an uber deal. Honda dealers should be able to do the job for roughly that amount.
Old Nov 5, 2014 | 05:05 PM
Acura told me 2k
Old Nov 6, 2014 | 09:17 AM
Jackass's Avatar
Originally Posted by markie.markvipTL
Acura told me 2k
Correct...but I said Honda.
In my area, the Honda dealership was the same as going to an independent shop. Acura was about double what Honda was charging.
Old Nov 6, 2014 | 02:41 PM
pohljm's Avatar
For me its $350 for TB service labor maybe $100 more for valves
Old Nov 6, 2014 | 05:52 PM
Honda over here
In CA
Are bout the same
Just like target and walmart
Sometimes honda is more expensive
Old Nov 15, 2014 | 12:26 PM
DMZ's Avatar
DMZ
Head a da Family
Paul, our mechanic in NJ charges $250 for the valve adjustment. $400 total labor if the valve adjustment and the timing belt job are done at the same time. Just add the Aisin kit! That means around $600 parts and labor, just like when I did my clutch.
Old Apr 3, 2016 | 02:15 AM
gsxrem's Avatar
6th Gear
Good info, my 2004 MDX is at 205K and need a valve adjustment. I may just have the valve adjustment and the timing belt job done together.
stalloutboy
Apr 25, 2016 10:28 PM
IlliniAcura
Sep 19, 2015 09:31 PM
Sep 17, 2015 09:01 PM
Sep 14, 2015 10:48 AM
Tsov Tom
Sep 6, 2015 07:56 AM
