Power Steering Pump Replacement
Old Dec 4, 2011 | 10:34 PM
djcobra316's Avatar
Hi guys i have a 2007 Acura TL that needs to get its power steering pump replaced. Has anyone here ever got this replaced and how much did it cost. My steering wheel is hard as hell which I cant even turn it when its parked. When my car is started up in the morning has loud whine noise and goes away after its warmed up, so please anyone who can help me with this would be a big help.
Old Dec 4, 2011 | 11:12 PM
gwiffer's Avatar
Are you sure the rack hasn't failed also?
I think a failed rack can cause metallic bits to be pumped through pump, causing it to fail over time.
I would definitely examine some of the power steering fluid and do a complete flush before you replace any parts.
Old Dec 5, 2011 | 12:42 AM
gatoferoz25's Avatar
My boy did that in his 07 base TL an bough it from a local junk yard for 125 included the pulley too so I did the rest
Old Dec 5, 2011 | 05:32 PM
djcobra316's Avatar
I did check the power steering fluid and there is not bits of matallic bits in the fluid. gatoferoz25 if your close by we can set up a time to meet up i live in central jersey.
Old Dec 5, 2011 | 05:35 PM
ArthurL's Avatar
The noise can be fixed by purchasing a brand new O-ring from the dealer.
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-whine-fix-754586/
Old Dec 7, 2011 | 03:54 PM
My zip is 07047 get the part an we talk
Old Dec 27, 2011 | 01:23 PM
ILLustriousUA6's Avatar
Feenin on some 20's
can anyone verify if this part can be bought at a Honda dealership??? My local Acura Dealership is about 30 mins. away.
Old Dec 27, 2011 | 01:34 PM
TheDingo's Avatar
Resident Dingo
Yes, it can be bought at the dealer. Call them first to make sure they have it in stock before you go up there.
The dealer here (45 minutes from me) makes me pay for parts before they are ordered so I have to make the trip twice. Bastards.
Old Dec 27, 2011 | 02:19 PM
Scottwax's Avatar
Mr. Detail
My local Honda dealer had several in stock. Guess they order them right before it gets cold.
Old Dec 27, 2011 | 04:50 PM
Bearcat94's Avatar
AZ Community Team
https://acurazine.com/forums/showthread.php?t=754586
Usually.
Any of the seals going bad and letting air in could cause the issue. But the OP seems to have bigger issues than just the noise.
PS pump is easy to replace. There are Service Manual scans as noted below:
A-105: DIY: Power Steering Pump Rebuild
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-pump-overhaul-pics-sm-scans-841134/ - With Pics and Service Manual Scans
https://acurazine.com/forums/showthread.php?t=754586 - PS Whine Fix (O-Ring Replacement)
Old Dec 30, 2011 | 04:59 PM
AMIC's Avatar
Fightin' Texas Aggie
Just had to have quite a bit of power steering work done. Had several leaks and the bad O-ring. Noise was terrible but never lost power steering.
TL-Rocket
Apr 29, 2023 02:33 AM
Feb 25, 2020 09:57 AM
spidermankb
Mar 5, 2019 11:34 AM
mike from annapolis
May 7, 2017 08:21 PM
asahrts
Sep 4, 2015 05:55 PM
