Power steering making noise
Old Jan 30, 2013 | 09:58 PM
DevtypeS's Avatar
Do you guys know the part number for the O-ring I need to change and how can I flush out the power steering fluid and refill with new one
Oh a 2007 TLS
Old Jan 30, 2013 | 10:02 PM
makk's Avatar
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-whine-fix-754586/
Old Jan 30, 2013 | 10:03 PM
DevtypeS's Avatar
Oh ok thanks how I go about flushing it out
Because the fluid look a bit dirty
Old Jan 30, 2013 | 10:35 PM
makk's Avatar
Did you read the thread?
Old Jan 31, 2013 | 12:09 PM
geekybiker's Avatar
Did you ever have the recall done? They do this for free if not.
Old Jan 31, 2013 | 12:19 PM
Project 04TL's Avatar
all of this is in the garage .. how many miles? just rebuild the ps pump .. its really cheap and its pretty easy. really good diy in the garage for this.
Old Jan 31, 2013 | 12:38 PM
DevtypeS's Avatar
I'm getting the recall done now but I ask the parts guy if the will change the oil he said no because I'm not getting a flush I'm just getting the line change and the service lady don't know
Old Jan 31, 2013 | 12:39 PM
DevtypeS's Avatar
Do you guys think they will change it since they doing the line
Old Jan 31, 2013 | 12:42 PM
3 bottles of ps fluid are included in the recall, why wouldnt they use them?
Old Jan 31, 2013 | 01:58 PM
Will Y.'s Avatar
Registered but harmless
Because they may want to save the money and time by not doing the flush and not changing the low-pressure inlet orange O-ring that comes with the recall kit.
Old Jan 31, 2013 | 02:49 PM
DevtypeS's Avatar
No they didn't even do a flush or change the oring I have to do that myself smh.but I buy 2 bottles if powerstreering fluid and the oring to do it myself
DevtypeS's Avatar
2 bottles should be ok right
Old Jan 31, 2013 | 02:57 PM
i used 2 1/2 when i did mine.
Old Jan 31, 2013 | 03:00 PM
DevtypeS's Avatar
Damn I only have 2 bottles can I use that Or I have to buy another bottle
Old Jan 31, 2013 | 03:06 PM
if i used 2.5 when i did my flush, and you have 2 right now. Math would tell me you would need another bottle to make up .5 you are short.
Old Jan 31, 2013 | 04:53 PM
DevtypeS's Avatar
Kool
Old Feb 6, 2013 | 05:21 PM
phineasboggs's Avatar
What is the recall about please? I have a groaning steering wheel after driving for a while. Don't know what to do.
Old Feb 6, 2013 | 05:34 PM
geekybiker's Avatar
Pretty much all the TL's had a power steering recall. If you call a dealer with your VIN they can tell you if it needs to be done.
Old Feb 6, 2013 | 05:38 PM
I'm so sorry, the search I did was for RDXs and didn't mean to intrude. Iwonder if the RDXs follow suit with the steering issue? What were your symptoms?
Old Feb 6, 2013 | 06:06 PM
swoosh's Avatar
takin care of Business in
No symptoms....the PS hose was tooo close to the rear head/cat and hence prone to cracking and PS pump failure....when you take it in, they are supposed to
1> remove the hose
2> replace with high temp hose
3> insulate it
4> switch o-rings
5> flush your PS system....
but they do not do any of that....all the do is insulate the existing hose....
If I were you, I would just perform this:
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-pump-overhaul-pics-sm-scans-841134/
and a flush
Old Feb 6, 2013 | 06:12 PM
Thanks! I need to go to a regular mechanic and tell him what to do. I'm a useless DIYer and cause more problems than help. E.g., I dropped the Steering Fluid cap and it seems lost forever. Any suggestion for getting new cap?
Old Feb 6, 2013 | 06:14 PM
Thanks, but I won't call my dealer with anything. They really screwed me over a few years ago, and I don't trust them at all. I'll need to do my own research. And thanks for helping.
Old Feb 6, 2013 | 06:15 PM
swoosh's Avatar
^^^ got a coke/pepsi 500ml plastic bottle at home? use the cap
I did the same when I started working on the car and lost the cap forever....put a coke cap on it, took it to the dealer and got a new cap
Old Feb 6, 2013 | 06:42 PM
That's a hoot! But, this was a resevoir near the windshield and near the steering. I had taken it off to see if it was, in fact, the steering resevoir and was trying to read it and . . . whoops. It's about 2 inches in diameter.! Glad to have company losing this.
Old Feb 6, 2013 | 07:14 PM
GKinColo08TL's Avatar
Power steering hose...git er dun.
Old Feb 6, 2013 | 08:41 PM
makk's Avatar
Is this for your RDX? There is a TSB for some RDX's for leaking power steering hoses. Can't recall what warranty implications there were or if ther was an extension for time/mileage. I will dig it up Thursday, bu you can see I your deler will help.
TL-Rocket
Apr 29, 2023 02:33 AM
Feb 25, 2020 09:57 AM
mike from annapolis
May 7, 2017 08:21 PM
asahrts
Sep 4, 2015 05:55 PM
