Power Steering Leak
Old Feb 17, 2020 | 01:03 PM
NoZixxx's Avatar
Power Steering Leak
I read that O-Rings on a 2007 TL usually need to be replaced. I heard a whining noise and my fluid was low so I replaced one of the O-rings because the outer metal looked like it was leaking. After I replaced it, I filled the reservoir but when I checked the level it went down a bit and there was a small spot of oil on my driveway in that same area. The whining is gone and looks like a smaller leak now. Do both O-rings usually need replacing?
Old Feb 17, 2020 | 01:54 PM
keep an eye and see if it's not just residual.
Old Feb 17, 2020 | 02:34 PM
WDPanda's Avatar
If you see oil on the floor, you should easily see where it's coming from. Look from the top at the power steering then cross your fingers and look at the steering rack.
Old Feb 17, 2020 | 05:47 PM
NoZixxx's Avatar
I am monitoring the level and it looks as though its residual. The level in the reservoir has not gone down since a few days ago.
MareckD
Jan 12, 2019 05:20 PM
aidian93
Jan 5, 2013 08:11 AM
speedemon90
Mar 28, 2011 11:01 AM
Nicki
Mar 21, 2011 01:32 PM
jdsmit13
Aug 17, 2006 01:10 PM
