power steering
Old Aug 6, 2006 | 03:28 PM
jdsmit13's Avatar
power steering
I have a something wrong with my power steering. First I noticed a clicking noise when I turned the steering wheel. I checked power steering and it was low I added a bottle of power steering fluid and it was low again within a day. The noise is getting louder and fluid is leaking all over. How do I fix this problem?
Old Aug 6, 2006 | 05:46 PM
fsttyms1's Avatar
Find th leak
Old Aug 8, 2006 | 01:28 AM
adamlee05's Avatar
Thread Police Chief
Originally Posted by fsttyms1
Find th leak
LOL
Old Aug 12, 2006 | 06:30 PM
jdsmit13's Avatar
I found the leak... top of reservoir and hose at bottom of reservoir. Is there supposed to be a seal on the cap to reservoir?
Old Aug 14, 2006 | 03:42 PM
acurabum's Avatar
Fluid should not be flowing at the top of reservoir ... how did you top the level up ?
and hose should has a clamp to tight the hose to reservoir ...........
Old Aug 14, 2006 | 04:23 PM
fsttyms1's Avatar
Exactly what i was thinking. The fluid level shoulndt be high enough to come out. there is no seal on it. just friction from the cap and its fins
the hose should have a clamp on it
Old Aug 17, 2006 | 11:28 AM
jdsmit13's Avatar
I know fluid is not supposed to be coming out of reservoir, but it is. What could this mean? Is there pressure or heat inside of reservoir causing this? Is it pump or rack? Please be specific fstsymms. you have been great help in the past.
I DID NOT OVERFILL RESERVOIR!!!
Old Aug 17, 2006 | 01:10 PM
fsttyms1's Avatar
Is there a crack in the side or the cap that you cna see? With the car running can you see the fluid bubbling out or over the top? Have someone turn the wheel with the car running to see if it causes it to come out??
Acura604
20
Aug 5, 2017 12:55 AM
Jul 16, 2017 07:33 AM
Euro4gen
Dec 12, 2015 03:14 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
