Power outlet socket not working
Old Jan 15, 2011 | 07:54 PM
TypeSDragon's Avatar
Loving my 08 TLS!
Does anyone why the 12v car socket both the one in the armrest and the one below the console all of sudden stop working. I don't use it much, but I needed to put air in my tire this morning and none of the socket worked when I plug in the air compressor. I checked the owner's manual just incase if there is a switch that you can turn off, but didn't find anything. Any ideas will help. Thanks!
Old Jan 15, 2011 | 07:56 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
It might be the fuse.
Old Jan 18, 2011 | 11:01 AM
Loving my 08 TLS!
Does anyone have a screen shot of the fuse diagram? Thanks
Old Jan 18, 2011 | 11:32 AM
LoveMyTL-S's Avatar
Look underneath the fuse cover. Should be a diagram there.
Old Jan 18, 2011 | 11:50 AM
nfnsquared's Avatar
Owner's manual, pg 248.
Old Feb 21, 2014 | 12:05 PM
Abe_Froman's Avatar
I checked the fuses below the steering wheel and even took my dash apart to check to see if the plug was plugged in to the power outlet.
I still cannot get it to work though. The fuses I changed even though they were good, and the power outlet was plugged in the entire time.
Does anyone know what else could be causing this? Is there a fuse inside of the hood that also needs to be checked? I can't imagine what else it could be.
Old Feb 21, 2014 | 07:56 PM
mzilvar's Avatar
Here's the schematic diagram for 07/08.
There is a relay in the interior fuse box in addition to the fuse and there is another fuse in the engine bay fuse box.
3 fuses in total could cause your problem.
#9 in the cabin is the accessory fuse and would prevent power from making it to your accessory sockets.
#32 in the cabin is for power to the relay and if it blew would prevent the relay from ever energizing thus preventing power from ever making it to your accessory sockets.
#15 in the engine bay feeds power to your #9 fuse in the cabin.
If the accessory power socket relay went bad you would also have this problem.
See schematic.
I'm assuming your car starts, so #22 and #23 in the engine bay that are also part of the circuit are good, if either of them went the car wouldn't start.
Attached Thumbnails Power outlet socket not working-accessory-sockets-07-08.jpg
Old Feb 21, 2014 | 09:07 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Just as a sanity check, you do have the ignition in the ACC or ON position - right?
Old Mar 2, 2014 | 10:56 AM
Abe_Froman's Avatar
See schematic.
I checked number #15 in the engine bay and it was good, but I replaced it anyway. Unfortunately it is still not working. So far I've replaced all three of the fuses that you said.
Is there anything else that I'm missing?
Haha, yes I do make sure that the ignition is on the ON position.
Old Mar 2, 2014 | 01:00 PM
Will Y.'s Avatar
Registered but harmless
Check whatever it is you are plugging into the outlet; turn the plug a little bit to make sure the contacts on the plug are touching the outlet walls.
Better yet, get a GPS or cell phone charger that works in another vehicle and plug it into the outlet to see if that device works.
G/L.
Old Mar 2, 2014 | 05:15 PM
mzilvar's Avatar
If you have a DMM you can measure voltage on the accessory socket to see if it's present.
Or a test light, clip it to ground and then probe the center terminal of an accessory socket.
If it lights power is present, if not then something is wrong.
There's a relay in the interior fuse panel, it may be bad or may have come loose.
Old Feb 23, 2016 | 04:02 PM
PhucDatBich's Avatar
2005 Acura RL power outlets not working
Both outlets in my 05 RL suddenly stopped working. Sure enough it was a blown fuse (fuse #9, 20A, drivers side interior). Works fine now after changing fuse. (Fuse box in engine compartment has a fuse puller tool).
Old Feb 24, 2016 | 07:33 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Welp, ya searched!
Old May 15, 2021 | 02:52 PM
Jeff Urbz's Avatar
6th Gear
My yellow fuse #9, 20A, drivers side interior in engine compartment keeps blowing. Changed it 3 times and it still keeps blowing. Any ideas as to what's causing it?
Old Dec 16, 2024 | 09:53 PM
sflaherty's Avatar
Hello I have mdx 09 is this diagram the same. Also which slot do you replace the I d
See schematic.
Old Dec 17, 2024 | 06:54 PM
sflaherty's Avatar
Originally Posted by mzilvar;[url=tel:14903375
14903375[/url]]If you have a DMM you can measure voltage on the accessory socket to see if it's present.
can you show me the relay loca in 09 base model? I don’t know which relay to test
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
acurajj
Sep 19, 2015 03:47 PM
quake97
Aug 30, 2015 07:57 PM
