Power Mirrors & Memory Seat Problem
Old Mar 11, 2010 | 08:53 PM
LEGEND_101's Avatar
Hello A-Ziners! My outside power mirrors on my 05 TL Nav are acting up. Not sure if it's the mirror switch or what. My power mirror controls only move the mirrors to the right or down. It does not move up or left. This happens on BOTH mirrors. Also, when switching the switch to the center position, the passenger mirror does not move down when reversing. I thought it was the switch, so I went out and bought another one from Ebay. Same thing happens! So I'm guessing it's not the switch.
Also, not sure this is relevant or not, but my memory seats stop working the same day the mirrors gone berserk. My car does not recognizes to adjust the driver's memory seat positions when driver One or Two is entering the car. My memory seats cannot be programed either. I've configured the driver settings on the dash, but that's only limited programing. I've tried searching around briefly but couldn't find anything useful. Can anyone please help?
thanks in advance.
Old Mar 11, 2010 | 09:11 PM
nfnsquared's Avatar
Did you check fuses? If your windshield washer doesn't work or the green light on the rear view mirror won't light up, it's definitely a fuse.
Old Mar 11, 2010 | 10:54 PM
LEGEND_101's Avatar
No, I have not checked any fuses. I figured since the mirrors go right and down, then it should still be good. And yea, the windshield washer doesn't work OR that green light doesn't come on either. I'll check for fuses tomorrow. Crossing fingers.
Old Mar 12, 2010 | 03:35 PM
nfnsquared's Avatar
It's fuse #20 in the under dash fuse box. There is a TSB to replace this fuse with a 10A fuse (originally 7.5A). Most of the time, the fuse blows when you try to spray water with a frozen line. The washer motor overloads the circuit.
Here's the link to the TSB:
http://www.in.honda.com/Rjanisis/pubs/SB/b05-033.PDF
Old Mar 12, 2010 | 09:42 PM
LEGEND_101's Avatar
OMG! It WAS the fuse! Of all things I shoulda known to check that first. Now that I recalled, it was snowing one day and I tried to use my windshield sprayer to get the ice off the windshield. Replaced it and everything worked perfectly now. Funny how one fuse controlled all those items. That completely threw me off. Thanks a lot for the help.
Now, Anyone want to buy a window switch?
Old Mar 13, 2010 | 02:35 AM
eg5's Avatar
eg5
user title goes here
so guessing the seat memory is back to normal again
Old Mar 13, 2010 | 01:03 PM
LEGEND_101's Avatar
Yep, Everything is working. Memory seats, power mirrors (all functions), & windshield wiper washer. I was about to blow a fuse myself when all these started failing at one time. (no pun intended) hahah
Old Mar 13, 2010 | 02:48 PM
pohljm's Avatar
glad you solved it, but that is crazy that the mirrors worked in two out of four directions sure sounded like a switch problem to me as well. So are there two fuses for these devices? one for left and up? and one for right and down?
Old Jan 18, 2011 | 03:23 PM
erso banks's Avatar
i just had the same problem and went to change the fuse,problem is the fuse isnt blown. i changed it anyway and still all the problems are still there. anyone know what to do? should i pull all fuses 1 by 1 and see whats blown?
Old Jan 18, 2011 | 04:20 PM
nfnsquared's Avatar
Are you sure you replaced fuse #20 and not some other fuse? It's in the center row, third fuse from the right.
And we're talking the fuses in the under dash fuse box, NOT the under hood fuse box
It's the only common denominator for seat memory, washer, side mirrors, and dimming rear view mirror light.
Old Jan 18, 2011 | 04:47 PM
erso banks's Avatar
ok , since im a jerk lets see. i did it from the driver side, so by right do you mean cosest to the seat?
Old Jan 18, 2011 | 04:49 PM
nfnsquared's Avatar
No, by "third from the right", I mean from the firewall.
There's a diagram on the back of the fuse box cover in case you haven't seen it. It's also on page 248 of the owner's manual. You need to replace it with a 10A fuse.
Old Jan 18, 2011 | 04:50 PM
erso banks's Avatar
EUREKA!!!!!! off to the car with a flashlight and tweezers!!!!!!!!!!!!!!!!!
Old Jan 18, 2011 | 04:53 PM
nfnsquared's Avatar
You have a fuse puller in the under hood fuse box...
Old Jan 18, 2011 | 05:43 PM
erso banks's Avatar
wish i knew i had a fuse puller,i ran to autozone and bought cheapie needlenose. well,it worked,thanks. i thought i was fairly intelligent so i thought the fuse box lid corresponded to the fuses but it was backwards or so i thought.
Old Jan 18, 2011 | 06:57 PM
nfnsquared's Avatar
Glad you figured it out!
This forum is a wealth of info. Spend a little time reading and searching this forum and you'll be up to speed in no time. A read through of your owner's manual will help a lot as well. If you're going to be doing a lot of your own maintenance I highly recommend spending the $50 or so to purchase the service manual from helminc.com. Same goes for electrical mods: the ETS manual (Electrical Troubleshooting Manual).
Register your car at myacura.com and you will also have access to an online owner's manual.
Old Jan 18, 2011 | 07:13 PM
erso banks's Avatar
thanks alot. i did a little reading but didnt find exactly what i was looking for. i do love my tl though. im having another problem that people fixed quickly,but of course i cant. wanna hear it?
Old Jan 19, 2011 | 03:23 PM
erso banks's Avatar
guess not.
Old Jan 19, 2011 | 09:04 PM
nfnsquared's Avatar
guess not.
Sorry, I ignored this thread once I saw your issue was fixed.
Just start a new thread for your other problem.
Old Jan 19, 2011 | 09:32 PM
erso banks's Avatar
ok,thanks.
Old Jan 22, 2011 | 02:19 AM
LEGEND_101's Avatar
OK, just realized something. I've found out what the problem was today. As I was cleaning the car, I realized that my rear passenger door does not lock with the remote OR using the front door lock controls. It was open the whole time! Kinda scary to think about cause we take this car everywhere. Grocery shopping, busy Holiday shopping at the mall, even at night she was parked outside. That door was never locked and there's no alarm. If you push the knob down, then it'll lock but power door locks won't pop it back up. I checked fuses and even open up the door panel to see what's going on but nothing. Do I need a new door lock actuator?
Old Feb 7, 2011 | 10:12 PM
co27blue's Avatar
5th Gear
Exclamation Thanks!
Thanks so much for this info!
I have the same problem with the mirrors only going 2 directions, seat memory not working, and dimming rearview not lighting up. I knew I should check here before paying someone too much money to figure it out for me. Picking up a fuse tomorrow! (I never realized how much I would come to rely on the seat memory!)
Old Dec 12, 2011 | 04:26 PM
melvin2816's Avatar
05 TL NBP 6spd S front
It was fuse #20 under the dashboard.
It has been very cold and this morning I try to the winshield wifer fluid and it was frozen and everything did not work as mention.
Thank you Acurazine again
Old Dec 13, 2011 | 09:28 AM
carbngrytl's Avatar
I have the same problem. But my mirrors don't work at all. Dealership said its the mirror control unit.
Old Jun 16, 2012 | 09:57 AM
canitolindo's Avatar
My mirrors work but not the memory seating
Old Jan 3, 2014 | 04:31 PM
USNA93's Avatar
Here's a link to the SB: /tsb/3gTL/b05-033.pdf
Old Mar 16, 2014 | 10:06 AM
Peepz314's Avatar
9th Gear
I'm having the same issue no and I see that it quite common. I know where to turn to get answers for my TL. wife was out in the car and noticed it so she's stopping to get fuses now. Fluid is full, but not squirting out and the mirrors work in only 2 of 4 directions like another member mentioned a few years back.
Old Mar 16, 2014 | 10:36 AM
Peepz314's Avatar
9th Gear
Nope! Not the fuse, but did change it from a 20 to a 10. Anyone else have any suggestions?
Old Mar 16, 2014 | 02:41 PM
Will Y.'s Avatar
Registered but harmless
Better check that fuse replacement-- the OEM #20 was a 7.5A, which was to be replaced by a 10A per the TSB.
If you pulled a 20A to replace with a 10A, you probably pulled the wrong fuse.
Once you get to the 7.5A in the #20, pull it out and replace it with the 10A even if the 7.5A looks good.
Old Mar 18, 2014 | 04:15 PM
Mugen.Justice's Avatar
I had a nice encounter with this problem this morning. Mirrors spazzed out, none of the memory buttons lit up / worked. Symptoms are exactly what others described. I spent some time reading up on the threads and had planned to pick up a 10A fuse after work.
The thing is...after work, I got into my TL and started it as normal. No spazzing mirrors. Hmm. Tried the windshield wipers. They worked. Pressed the memory buttons. They worked normally as well.
So...is the fuse not blown, then? Could it be due to the change in temperature? (It was 13 F in the morning. I believe it was 36 F when I left work in the afternoon.)
What say you?
Old Mar 19, 2014 | 06:28 PM
JesseDean's Avatar
9th Gear
I have an issue with my memory seats wonder if it could be a fuse
Old Mar 31, 2014 | 11:28 AM
Peepz314's Avatar
9th Gear
Problem fixed!! was reading the fuse chart wrong and replaced the heated seat fuse instead..lol
When you slide the fusebox case or door off, flip it down under the fuses to get the correct reading. The pull arrow should be going to your left on the grey side.
Old Aug 31, 2015 | 08:03 PM
Jlora's Avatar
Hey
My side mirrors always change direction on me, it moves The direction I want it to but when I turn my car off they face down, also if leave the little switch on left or right they move when I change from drive to reverse or park. Could that be a fuse problem also ??
Old Sep 1, 2015 | 09:11 AM
Slpr04UA6's Avatar
-------Tim-------
^try putting the switch in the middle (neither mirror will tilt when in reverse). The mirrors will tilt (drivers or passenger which ever is selected) when put in reverse. It's so that you can see a curb, or parking line when backing up.
Also, you may need to reprogram memory controls for "driver 1" or "driver 2" remote keyfobs.......
Welcome to Azine!
Old Sep 1, 2015 | 01:20 PM
Jlora's Avatar
Welcome to Azine!
Thanks a lot man , honestly I didn't know what the driver 1 or driver 2 was hey do u know anything about under the hood ??
Old Jun 16, 2016 | 03:39 PM
cbbarker1's Avatar
TL 2005 power seats
I have tried the suggestion of replacing the 7.5 amp fuse with a 10amp fuse put I still cannot clear/change the memory on my power seats. Any other suggestions?
Old Dec 5, 2016 | 01:00 PM
VisualEchos's Avatar
Andrew
Kinda weird on my car, had the issue, went to replace the fuse and it's a 15A (and has never been replaced). The fuse appeared good, but when I replaced it with another 15A I had lying around, it fixed the problem. Weird that.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
PortlandRL
Sep 14, 2015 12:01 PM
