Power Door Lock
Old Jan 15, 2013 | 05:14 PM
MacKenzie001's Avatar
Power Door Lock
My driver side power door lock stopped working intermittently a few weeks ago with it more less just not working lol and the occasional time it kicks in. So I did a search and found actuators seem to be a common cause. So I figured I'd go ahead with replacing it, but lately its been acting a little weird. The doors are set to look automatically when over 15kph, and I've notcied that after the initial lock on take off, anytime I go below 15 and then speed up again they all try to lock again, as in I can hear the little actuators try to lock the already locked doors. Also when tryin to lock the doors I can hear the driver side door lock motor whirring as though its trying to lock as well. My question is, does this still just sound like the actuator? Will replacing it solve my issues? And is the actuator potentially repairable or just replaceable?
Thanks Mak
Old Jan 15, 2013 | 09:38 PM
LoveMyTL-S's Avatar
Have you tried adjusting the timing for the lock? Set it for a longer time and set it back. See if that fixes your issue.
Old Jan 16, 2013 | 03:19 PM
Will do, but I dont think thats going to cut it. The constant relocking of the doors is intermittent but the vast majority of the time the drivers door will not lock thru the fob or button on the door. I believe this to be the main issue and perhaps why the car is constantly trying to relock the doors as the driver side will not lock.
tman570
Jun 11, 2019 07:56 AM
Azonics
Sep 22, 2015 05:28 PM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
