Poor engine performance - '04 TL
Old Oct 19, 2011 | 11:55 AM
cowboyshoes's Avatar
3rd Gear
I have a 2004 TL with 75k miles. In recent months I've noticed sluggish performance in acceleration. The engine seems to "flutter" when accelerating, notably in the 30-35 mph range where you can actually feel the car shimmy. When the car is driven hard I notice a sulfur or "rotten egg" smell frequently. Also the overall MPG is slightly lower (2 to 3 MPG) than it used to be.
I've just had the belts, transmission fluid and spark plugs replaced. This has helped a little but the symptoms described above are still present. I've always used 91 octane gas, get frequent oil changes with full synthetic and also use Seafoam in gas system a couple times a year. I've tried to reset the computer (turn key to position II and hold down gas pedal for 30 secs.) but this hasn't helped.
Any suggestions would be greatly appreciated!
Old Oct 19, 2011 | 02:41 PM
garrett's Avatar
that may not be the engine but the transmission hesitating on shifting... Have you ever changed your 3rd and 4th gear pressure switches?
Old Oct 19, 2011 | 10:34 PM
05AV6's Avatar
Your app sensor may be on its way out, surging, hesitation and fluttering are all classic symptoms.
Old Oct 20, 2011 | 12:21 PM
3rd Gear
I've not replaced these switches but will look into it. Is it costly?
3rd Gear
Is it worth replacing this sensor proactively?
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
Sep 15, 2015 06:44 PM
Sep 14, 2015 10:09 PM
