PLEASE HELP!! Major Clutch Problem
Old Feb 12, 2014 | 09:11 PM
jtindel's Avatar
5th Gear
I have a 2004 TL Sport. It currently has 125,000 miles on it and everything else seems to be in good shape. I have had this problem since about 95,000 miles.This problem would only happen after heavy acceleration, however here lately it has gotten much worse.
Sometimes when i first get in the car, I have to pump the pedal. It is rock hard, and with a few pumps its back to normal. After it is pumped a few times, it becomes drivable. When I'm entering the highway or just accelerating hard, the clutch works until I put it in neutral and let the RPM's come down. The next time I push the clutch, it is rock hard and doesn't engage.
The syncros have taken a hit a few times, but if I'm careful, I can double clutch it. I am not going to risk my transmission. So I am going to stop driving the car.
I flushed the hydraulic system......didn't help
I replaced the master cylinder......... seemed to make it worse
I replaced the clutch hose............. didn't help
pulled the entire hydraulic system and cleaned it. . did nothing
removed the slave cylinder and cleaned it.......... did nothing
The only thing is the clutch. I DO NOT want to do the clutch.
I have seen one post about this and their remedy was replacing the clutch.
has anyone else heard anything about this?
Why is this happening?
Am I overlooking something?
Thanks for the advise
Has anyone encountered this problem
Old Feb 12, 2014 | 10:38 PM
ez12a's Avatar
the overexplainer
i think it's the clutch.
usually when the MC or SC go it's a limp pedal, not a rock hard one.
if it's rock hard i feel like it's a problem with the pressure plate, especially if you've done all that work to the hydraulic system.
Old Feb 12, 2014 | 10:55 PM
jtindel's Avatar
5th Gear
Thats a good idea. it could be that. after racking my brain for a while i think i might have come up with another possible cause. The throwout bearing rides on a shaft. The clutch wearing out sends out dust. Dust accumulated on the lubrication on the shaft causing the throwout bearing to bind and not slide on the shaft. Thoughts?
same fix as the clutch... all is replaced at the same time.. but this makes sense to me.
Thanks for the reply!!
Old Feb 13, 2014 | 01:33 AM
ez12a's Avatar
the overexplainer
possibly, also the fact that our pressure plates are self adjusting, a number of things could be wrong with it so it gets stuck and doesnt disengage.
completely different in design but my old '93 integra when one of the clutch dampening springs popped out the clutch pedal became very stiff. So maybe in your case something is obstructing the PP or the leaf springs in it are broken.
good luck!
Old Feb 13, 2014 | 08:43 AM
Turbonut's Avatar
Many threads and they all end with a fix,new clutch assembly.
Example:
https://acurazine.com/forums/3g-tl-problems-fixes-114/very-hard-clutch-pedal-feel-3g-6sp-tl-when-wot-tires-breaking-loose-read-750672/
Old Feb 13, 2014 | 12:45 PM
jtindel's Avatar
5th Gear
Thanks for the help guys. I will be replacing my clutch this weekend. I will let you know how it goes.
Ol'Dave
Sep 5, 2020 02:56 PM
pstomps
Feb 20, 2017 03:29 AM
mugen_kid
Nov 13, 2015 10:38 PM
TxRzrBk
Sep 17, 2015 01:07 PM
heyitsvic
Sep 4, 2015 09:38 AM
