Please Help- door stuck!
Old Oct 28, 2006 | 07:06 PM
kali-k's Avatar
My driver's side rear door won't shut. The mechanism that holds the door shut (underneath the child lock switch) won't release. It just stays shut. (When I go to close the door, it hits the hook instead of latching to it.) The beauty is that when I was trying to figure out how to fix it on the driver door, the same thing happened and now neither door will shut!! I'm a genius! Anyway, it is the weekend and no one is open so I need your help! Thanks!!
Old Oct 28, 2006 | 09:07 PM
Ron A's Avatar
Administrator
Did you try pulling on the outside door handle again after it did this? That should put the catch back in the right position. It sounds like the latch thing has somehow gotten in the closed position while the door was open. If pulling on the outside handle doesn't do it, try moving the latch with a small screwdriver. If nothing else is broken, it should move easily without forcing.
Old Oct 29, 2006 | 06:33 AM
CobraGuy's Avatar
Like Ron said...just stick a screwdriver or similar behind the latch and pull out while you pull on the door handle. It will pop out for you.
Old Oct 29, 2006 | 09:24 AM
kali-k's Avatar
thanks!
Screw driver and door handle did it! Thanks!!!
Old Oct 30, 2006 | 05:18 PM
meburdick's Avatar
'17 RDX Tech AWD - WDP
BTW: This little trick works with all kinds of latches like this, on ALL vehicles. This includes your trunk and hood latches.
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
