Please help.. accelerating problems.
Old Apr 25, 2014 | 07:10 PM
4doorJ's Avatar
Hey guys, about 2 months ago, my car threw a c.e.l. for running to rich. I looked under the hood and my purge hose was ripped. I fixed it and light went off. Ran good for about a week but then starting hesitating a little on acceleration. I changed the plugs, coils, purge solenoid and then pulled off the intake manifold and cleaned out the egr passage ways and put a new egr valve on it.. it ran good for a week and then started slightly hesitating again on acceleration. It feels like it's bogged down and if I give it more throttle, it hesitates. It's so frustrating. Someone please help.
Old Apr 25, 2014 | 07:32 PM
Turbonut's Avatar
Engine light on?
Accelerator Pedal Position Sensor?
Old Apr 25, 2014 | 07:35 PM
4doorJ's Avatar
Originally Posted by Turbonut
Engine light on?
No check engine light.. I was thinking the app sensor but do those go out intermittently? Sometimes it hesitates and sometimes it drives like a brand new car.
Old Apr 26, 2014 | 01:30 PM
4doorJ's Avatar
85+ views and nothing... I know someone knows.. help!
Old Apr 26, 2014 | 02:36 PM
YeuEmMaiMai's Avatar
did you take your IM off and clean the passages? Idle relearn procedure?
Old Apr 26, 2014 | 02:38 PM
MarcoNorthPolo's Avatar
KCCO
Well no one knows the answer to your problem, but we can take guesses. You've done what I would have, which is doing the plugs, coils and egr valve. You can try resetting your ECU to see if it does anything.
Old Apr 27, 2014 | 12:19 AM
Will Y.'s Avatar
Registered but harmless
Yes-- there are several threads in this forum about the APP sensor going bad intermittently and unpredictably without throwing a CEL.
Turbonut posted the most likely issue in the second post in this thread.
Old Apr 28, 2014 | 10:12 PM
3RDGENTL757's Avatar
Did you clean your throttle body when you clean the passages out? And you need to do the idle learn procedure too
Mike734
Dec 10, 2021 01:25 PM
mlody
Dec 4, 2019 02:11 PM
joflewbyu2
Aug 18, 2019 10:38 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
