PLease Help!!!
Old 11-25-2008 | 04:09 PM
nyczballa's Avatar
Unhappy PLease Help!!!
I have a 2004 TL AT without Navi and 57K no warranty. The car runs great and hasn't really bean giving me problems. This morning I drove to the dentist with no problems and then to work with no problems. After work i got back into the car and my remote wouldn't work and That seemed strange I thought maybe the battery died but when I turned the car on and drove my signals weren't working, my memory seats weren't working, radio/cd player stoped working , and my integrated fog lights also stoped working. My power locks on driver side stoped working but not on passenger side. I don't understand what the problem may be. I checked all the fuses and it all of them seem to be ok. Please help me anyway you can its hard to drive because I have NO signals now... BTW the hazards still work.
Old 11-25-2008 | 04:25 PM
Trew's Avatar
That's weird. Assuming you have your radio code, try pulling the negative battery terminal for a few minutes. Not sure what could be causing this aside from major electrical problems, but if that were the case you would have probably noticed little things before all this happened.
Are you the first owner?
Old 11-25-2008 | 04:42 PM
nyczballa's Avatar
No I am the second owner..... I have owned the car for about 7 months now.
Old 11-25-2008 | 06:22 PM
csmeance's Avatar
have you had the windshield recently replaced? Did it rain while at the dentist's office?
Old 11-25-2008 | 07:03 PM
nyczballa's Avatar
yes it was raining while I was at the dentist's office but No I haven't had my windshield replaced. Do you know what it can be?
Old 11-25-2008 | 08:14 PM
LoveMyTL-S's Avatar
I had a similiar problem with my 04 TSX once. All kinds of electrical things didn't work. I was freaking out!! It turned out the be a fuser under the dash. Check your fuses again under your drivers side dash next to our dead pedal. Also check the fuses under the hood. Seems like it was a 20amp fuse but not positive. Hope this helps.
Old 11-25-2008 | 08:23 PM
LoveMyTL-S's Avatar
Perhaps this will help:
https://acurazine.com/forums/showthr...272&highlight=
In the TSX it was fuser #21....7.5amp. Not sure if it's the same for the TL.
Old 11-25-2008 | 08:25 PM
csmeance's Avatar
water leak to the multiplex unit, its near the fuse box if memory serves me right. The windsheild can leak causing that, or you have a clogged water drain.
Old 11-25-2008 | 08:32 PM
LoveMyTL-S's Avatar
This may help too:
https://techinfo.honda.com/rjanisis/...404O00242B.pdf
Click over to pages 6 and 7.
Old 11-25-2008 | 09:13 PM
nyczballa's Avatar
WOW thanks alot that good stuff I hope its something small like that. I will definitely changing my fuses Tomorrow but if it isn't the fuses what else can it be?
