PCV Valve pieces stuck in collar?
Old 04-12-2021, 08:05 PM
Deeguala's Avatar
PCV valve broke
Taking out the PCV valve the old one broke into pieces & I was stuck with taking off the valve cover & taking out the pieces. Trying to put in the replacement it doesn’t exactly fit into place & about an inch of it isn’t going into it. I stuck my finger inside the collar & felt like a sharp metal. Is it possible I broke a metal piece that snugs into the pcv valve or may it be possible there are still some plastic pieces of the old pcv valve stuck in there ?
Old 04-13-2021, 08:19 PM
Deeguala's Avatar
Hey guys, so a few days ago I made a thread about my replacement PCV valve not going all the way in about taking out the broken pieces of the original that broke. Some of you might say I should’ve been patient & waited for a response or looked at similar threads, but none really specify the risk of breaking anything if inserting a flat drive or pliers up into the whole to get the broken pieces out. I’ll leave a few pictures below & you can guys can let me know if that’s a piece remaining of the PCV or something else.
Old 04-13-2021, 09:42 PM
Valens's Avatar
I'm guessing the new PCV valve still doesn't fit? Then I would say yea, that is a broken piece then. It doesn't look like it belongs there to me.
Old 04-13-2021, 10:39 PM
Deeguala's Avatar
yeah pretty much new replacement not sliding in all the way in. Car has been sitting for 2 days cause of one little plastic component SMH lol
Old 04-14-2021, 01:45 PM
Acura TL Builder's Avatar
Does the replacement PCV valve have anything that looks like that?
Old 04-14-2021, 01:51 PM
Deeguala's Avatar
i wouldn’t know honestly. A lot of pieces fell out of it when I took the valve cover off the first time. Maybe some remained in there. Looks like a black plastic piece. Would you knowing it belongs there ?
Old 04-14-2021, 02:48 PM
Received 8,708 Likes on 6,715 Posts
Get an extra long wood screw and thread it onto the plastic piece and pull out. If that doesnt work, you may have to pull the valve cover off to get to it
Old 04-14-2021, 03:06 PM
Deeguala's Avatar
you certain that’s a plastic piece from the old pcv valve in there ? Looks pretty black & plasticish to me
Old 04-14-2021, 04:19 PM
I'm not certain about anything If you're very worried popping off the valve cover is your best approach to ensure you fully get it out.
a few threads of people in the past:
https://acurazine.com/forums/3g-tl-p...-broke-974253/
https://www.google.com/search?client...Aacurazine.com
ThatBlackTL
03-14-2022 05:52 PM
Deeguala
04-12-2021 08:05 PM
Saudade
03-14-2021 11:06 PM
whatwasthat
08-10-2006 12:40 AM
Quick Reply: PCV Valve pieces stuck in collar?
