Passenger side window works with key but nothing else.
Old Jul 27, 2014 | 02:34 PM
motoxkfx's Avatar
Exclamation Passenger side window works with key but nothing else.
Ok so i put in a door lock actuator today put everything back together worked great other than the auto window down would not work. So i messed with it a little bit, turned the car off and on then it started to work normal ok great. There was a pice of rubber that clicked every time the went up and down so i started to fix that i would move the pice of rubber then roll the window up and down to see if that fixed the sound. I did this about 10 times and the last time i rolled it down it would not come back up. I went to the house and did a little research and found that some people where able to use the key in the door. So i tried it and that worked but the buttons on the passenger or driver side neither work the passenger side window.
anyone have any ideas.
mike from annapolis
May 7, 2017 08:21 PM
HairyMonkey019
Apr 22, 2016 10:50 PM
justin7779
Dec 25, 2015 10:33 PM
JnC
Sep 11, 2015 06:06 AM
MyKids&Cars
Sep 1, 2015 12:53 PM
