Passenger Side Mirror Noise
Old Apr 1, 2006 | 02:23 AM
TL-Rocket's Avatar
Question Passenger Side Mirror Noise
Has anyone experienced a creaking sound from the passenger side mirror when it adjusts up/down when the transmission is placed in reverse? The passenger side mirror on my '04 TL has been making this sound for about 4 months and it seems to be getting worse.
Thanks,
TL-Rocket
Old May 26, 2006 | 02:06 PM
PriMo718's Avatar
Have you resolved this issue? I seem to be having the same problem with my passenger mirror when tilting in reverse.
Old May 29, 2006 | 01:55 AM
TL-Rocket's Avatar
I took it to the dealer (Acura of Auburn, MA) and the problem mysteriously disappeared. I think they lubricated it (or did something). In any case, they said that they didn't detect a problem. Sure enough, when I picked up the car the problem was gone.....
Anyway, that's what happened.
TL-Rocket
Old May 29, 2006 | 06:57 AM
sebounet2005's Avatar
TL 2012 SH-AWD TECH/UMBER
My motor inside was change to correct this issue. Lubrification is just a short term repair.
Old Aug 22, 2007 | 09:57 PM
Yzerguy's Avatar
Replying to an old thread, found this and a few other threads on the problem which has been happening to my 05 for a couple of months now. Next regular service I will ask them to look at it.
If it takes a motor replacement, so be it, but just in case anyone else is having the problem, I think lubrication (if done properly, and I can't say I'd know how that would work) could be the answer, not necessarily a motor replacement.
My side view mirror on the passenger side kinda "skips" down and makes clicking noises when tilting down for reverse, but only on warmer days (like most of summer), and the driver's side doesn't do that.
I've got the passenger side mirror selected all the time for reverse tilt-down, I rarely use the driver's side reverse tilt unless I'm parallel parking on the left side of a (one-way) street, or in really unfamiliar territory. Given only the passenger side does this and gets used all the time, I'm thinking it's a lube issue (also on cooler days, when lubricant should be less viscous, the problem isn't there).
I'm all for a complete motor fix/replacement if it needs it, but if not, I'm paranoid that "fixing" it will lead to further probs, potential scratches, yadah yadah. I think this is also the issue for the sun roof (moon roof?) tilt up function. On warmer days when tilting the roof up, it'll make a kinda groan (started after about a year), but not on the cooler days, on that one I'm almost sure it just needs lubrication... just need to find out where to lube and with what.
Any thoughts from members with similar issues wud be appreciated.
Cheers!
Old Aug 22, 2007 | 10:05 PM
ARX-01b's Avatar
Mine does it as well
Old Aug 23, 2007 | 07:01 AM
Turbonut's Avatar
Mine's the same, but even though it's under warranty, I just don't feel like letting the dealer do the fix. I guess I'm just paranoid, but if it gets worse, I might as well bite the bullet!!
Old Oct 3, 2007 | 01:44 AM
Yzerguy's Avatar
Finally a follow up to this, just took my TL in for sched. service, asked them to take a look at the passenger mirror... when I picked it up, the response was "you need a new mirror, covered under warranty". Great, I think...
I clarified that it's a whole new mirror and not the motor. According to dealership, it needs a whole new mirror, motor replacement is not an option... They're confident the new mirror will match color just fine ("Factory color..."), but I'm concerned -- not to mention the current mirror works, it just skips/clunks on warmer days.
Looking for feedback here, they ordered the new part and called me back to have it replaced this Friday (3 days from now). I know I'll definitely ask them to keep the old mirror after they replace it (just in case), I'm paranoid the new one won't match color, given most body shops beyatched like crazy about "the hundreds of Honda silvers" out there when I had my back bumper done (btw it's close, but not an exact match). The dealer says it's factory paint, won't be any probs, at all.
That all said, do I live with the old mirror, or hope for the best with a new one and ask them to swap it back (at my cost) if the new one is 2 shades different than the rest of the car? Didn't think this would involve anything more than at most a new motor, if not just someone who could figure out how to lubricate the current one...???
05 TL Navi SSM
Cheers, Sean
Old Oct 6, 2007 | 01:17 AM
Steerpike's Avatar
I noticed this on my brand new '07 TL, 4,500 miles only. Noise, shudder, jerky movement when passenger mirror lowers when going into reverse.
Look forward to hearding the final outcome.
Old Oct 7, 2007 | 04:55 PM
Yzerguy's Avatar
The end result was that they replaced the whole mirror (under warranty) -- so it works fine now but of course my TL is silver and therefore the new mirror is a slightly different shade of silver than the driver's side mirror...
What I suspect happens here is that the mirror was fixable, but would take a lot of labor, replacing the whole mirror is the faster (and cheaper) way to go for the warranty claim. Of course if I was outside of the warranty period I'm sure the only solution would have been to repair the motor itself and charge me 7 hours labor to fix a $250 part.
That said I and my detailer are the only two people who can see the difference, I'm picky that way... about 95% of people won't see it, especially because it's a part that hangs away from the rest of the car. I wanted them to keep the old mirror and give it back to me but they said they need to send it back to Acura for warranty purposes.
Yeah so I realize it doesn't help much... I'd think that you're ok with black, white, navy cars, but then again, I could be wrong.
Sean
Old Sep 26, 2008 | 03:39 AM
nicky767's Avatar
3rd Gear
for people who are having this issue...its becasue some how or another you pushed it back...nlike say it was snowing and you cleaned ur car, or some passenger decided to push on it...it happens. just push the mirror on the top until it clicks a couple of times. and the noise is going away. whats happenign is when it got pushed, its jumped a few teeth, the motor is desinged for all the teeth, so when it goes looking for the 3 you jumped, it grounds out and makes that clicking. its not a lubrication issue...its a quick fix.
Old May 30, 2009 | 12:39 AM
asianeagle87's Avatar
5th Gear
thanks i had this problem too
Old Jun 21, 2010 | 07:19 AM
Bayam0n's Avatar
Veni, vidi, vici
quick thread revival, iam having this issue, I just want to see if any one can confirm on this resolution??? I want to try it out, but I am not sure if it will make it worse. thanks.
Old Aug 20, 2010 | 08:07 PM
kaliboy's Avatar
Bump
I broke my passenger mirror and had it replaced (not the whole mirror unit, just the glass piece). When I put it into reverse it tilts down and then it goes all the way up and starts clicking when I get out of reverse. I think my motor is jacked.
I'll probably just keep the swtich off the center so it doesnt tilt rather than replace the motor/ mirror.
Anyone with advice on this?
Old Aug 20, 2010 | 08:14 PM
kaliboy's Avatar
i tried this too, didnt seem to work. it always ends up tilting all the way up and then starts clicking.
Old Aug 20, 2010 | 08:15 PM
Turbonut's Avatar
I say it's the actuator:
https://acurazine.com/forums/ramblings-12/a-78704/
Old Jan 7, 2014 | 03:26 AM
hostile429's Avatar
sorry to revive this thread.. but im currently dealing with this issue and its very frustrating. even while in motion my mirrors seem to act retarded on both sides with the clunking issue... now my mirrors wont move up or down only on the sides when pressing the switch
but i will follow this thread here https://acurazine.com/forums/3g-tl-problems-fixes-114/3g-mirror-repair-pictures-3g-garage-e-045-a-832020/
see if it helps
Old May 13, 2018 | 04:11 PM
Ronin904's Avatar
Works perfect!
@nicky767 Thanks for the post! I pushed my mirror back in place and now it works perfectly!!!
Old May 14, 2018 | 04:20 PM
donkiboy's Avatar
Do you push the mirror straight into the housing? Mine is making loud popping noise as it tilts down and jerks while doing so.
Old May 14, 2018 | 07:06 PM
Ronin904's Avatar
Yes, I just pushed on the top of the mirror straight towards the back of the housing and after a couple clicks it was back in place.
Old Jan 11, 2019 | 01:13 PM
Don Taylor's Avatar
Tried the push mirror back in track approach and it worked!
Love the person who gave the simple fix of pushing the top of the mirror so it would get back in the track! Tried it and it worked perfectly. No Lube! No motor replacement! No new mirror! No visit to dealership! No money spent! Thanks for the tip! Go simple first and work out from there!
rockyboy
Aug 4, 2024 10:35 AM
marcelft
Jul 10, 2018 06:17 PM
Oct 21, 2015 11:38 PM
sockr1
Oct 1, 2015 01:31 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
